WD Marvell utility manual is available in your update box
Postby ACE_Admin » 01.06.10, 17:41
Finally , WD Marvell utility manual was translated and uploaded to user update boxes. Please check the manual directory for Western Digital Marvell.pdf .
All comments are suggestions about this manual are appreciated in this topic.
tec
Re: WD Marvell utility manual is available in your update bo
Postby tec » 21.07.10, 17:45
Hi there Roustam, please explain how to use (and connect) the WDC Marvell USB?
Postby AJ2008 » 22.07.10, 13:49
Connect HDD via USB connection, then run WDC Marvel USB uility. Here you should see a box listing all USB devices, if your WD is not here then you may need to wait some more minutes.
when WD is identified, select it and press OK. Next, at family selection, you need select 'Kernel' then 'Autodetect'. The family should be identified if supported, though there are some families that are not supported. Now, you need start utility in Normal/Kernel and after loading of utility ID can be seen, and SA/ROM options are accessible
tec
Postby tec » 22.07.10, 15:54
Thank you Roustam, please supply a list of supported devices.
Postby AJ2008 » 22.07.10, 18:29
At present I think all disks are supported (Venus, Mariner, etc) except for WD10TMVV and the 750GB versions of this family, though Roustam should be able to clarify this.
tec
Postby tec » 27.07.10, 10:49
Roustam, please supply a list of the supported models
tec
Postby tec » 28.07.10, 12:19
Roustam, I have a WD10TMVV. The drive takes a couple of minutes to be detected by the PC as a WD My Passport 070A USB device but without access.
When trying to access the drive with the WDC Marvell USB utility the only drives visible in the list of available drives are the ATA/SATA drives attached to the PC.
Please assist.
Postby ACE_Admin » 31.08.10, 11:05
The method for WD 2.5 drives with USB interface is next.
1. connect the drive to your PC and wait until it is identified by system
2. enter WDC Marvell USB utility and select "Kernel" option
3. press autodetect button
The family should be selected automatically.
Then try starting utility and check if drive can read SA modules etc.
If your system did not identify drive , try to unscrew the board from HDA and connect it.
In this case, utility will detect correct family and let you read/write ROM from this drive.
When correct family is detected, it is possible to write native ROM to same family drive board with SATA interface and proceed data recovery.
mojimorady
Postby mojimorady » 28.09.10, 18:28
HI GURU
I did the steps you mentioned , in the lower window everything is ok , but in top left corner the MODEL,SERIAL,FIRMWARE AND
CAPACITY are not detected .
is the situation ok ?
how can we remove password from WDC marvell USB HDDs ?
looking forward to hear from you
regards
moji
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Ramtock
Postby Ramtock » 27.07.15, 09:44
ACE_Admin wrote:Finally , WD Marvell utility manual was translated and uploaded to user update boxes. Please check the manual directory for Western Digital Marvell.pdf .
Postby Amarbir[CDR-Labs] » 31.07.15, 16:53
What Was Your Question again ?
