hi
i have WD500BEVT 2.5" mariner series.
hdd is detect, but in module directory test i see this modules error:
0033 P-List (Primary defect list)
0034 G-List (Grown defect list)
0032 Relo-List (Candidate defects)
0036 T-List Module
i can't make image in DE,is there any chance to recover DATA?!
WD500 2.5" issue
Re: WD500 2.5" issue
Can you read with composite? If no, then read each copy of module with ignore read errors then use Winhex and try to make 1 good file from both copies saved. If possible I guess maybe they will not write to SA if SA is bad, but you can attempt hotswap then if you have good donor for it.
thank you AJ
i will try and mention the result.
hi again dear AJ.
with dir editor i changed the ABA position of those 4 modules then i tried to read them. i could read them then i saved each modules and rewrite them to the hdd again. still the header's are error after reading in modules directory and i can't reach the sectors in sector editor!
Dear AJ!
no answer or suggestion?!
you can write those modules from another hdd
p list c modules is not important
g , redo list write from another hdd
t list is important but you can test that
thank you Dear NSRgroup
