Hi there,
The drive : WD10EADS-11M2B3
At power up, it spins up and get ready.
I am able to Make HDD resources backup (modules, ROM, Tracks, SA) from copy 1, but on copy 0 it is very slow (a week is not enough)
In DE, it shows "empty partition table" and fall in ABRT error
Head test on utility indicate head 0 weak (not bad, but very slow)
Other heads are ok.
Is the head too weak for data recovery ?
What I have try for now :
- Clear SMART
- Solve Slow response
- Manual page 27 : 2.5
Switch heads map to the Default setting : this is the same, so I don't have done
Recalculate the translator : done, no progress
Edit head map in RAM : my next move
Hot swap : I don't have donnor PCB yet, what should I match ?
If I have to search for donnor heads, actually I search for 5th and 6th char in DCM. Is it true ? extended model is relevant too (-11M2B3) ? head map ?
because I have a donnor with DCM match (patient DGNNNT2CGB, donnor HHRCNT2MH) and donnor is 6-head, while patient is 4-head
Patient :
WD10EADS-11M2B3
DCM DGNNNT2CGB
Actual donnor
WD10EADS-00P8B0
Head maps unknown (pcb hs) but probably 0,1,2,3,4,5 - can't switch off Unnecessary heads
DCM HHRCNT2MH
Another potential donnor I have
WD10-EADS-00M2B0
DCM HARCHV2MAB
Many thanks for help
WD10EADS : need some help please (solved)
Re: WD10EADS : need some help please
Solved.
I found a compatible drive
- WD10EADS-11M2B3
- DCM HANCNT2MA
- S/N & DATE CLOSE ENOUGH
I switch heads, and I currently recover data.
- WD10EADS-11M2B3
- DCM HANCNT2MA
- cuumaytinh
- New user
