WD3200AAJS-60M0A1 03 module is bad
Sun
Postby Sun » 23.12.13, 11:29
I have a disk, WDL is WD3200AAJS-60MOA1, It have some bad sector in service area, and the 03 module is bad. How can I repair it?
Nick_TS
Re: WD3200AAJS-60M0A1 03 module is bad
Postby Nick_TS » 23.12.13, 15:11
Try to read damaged modules with ignore reading errors, what results?
Open it with ignore reading errors and look for DE AD letters. Replace DE AD with zeros. Save written data to HDD.
Postby AJ2008 » 23.12.13, 15:13
Sun wrote:Hi,
Short answer is no.
Long answer is that there are ways to rebuild it from some logs, but is very complex and is beyond my experience :cry:
Maybe you can read with composite read, try to block SA regions and you should reach SA via ABA on this model.
