The pattern is present throughout the whole used part of data, usually only on one head. Swapping heads does not change it.
The UNC areas are too close to each other (every 1000 - 6000 sectors, depends on the drive) so the data are unusable
Could it be a SA problem? Any idea how to fix it?
