wd2500aajs-65m0a0 fw needed
datasolution
Postby datasolution » 13.03.13, 17:51
dear all ,
I have wd2500aajs-65m0a0.drive id cant get.in log it shows no sa copy available,when i start drive in normal mode it get spt 1311 and becomes ready.i can test modules too but by id only.there i found ata mod bad.so i need it if somebody know to reallocate this mod to another good mod plaece i think drive should work.i cant find mod for this anywhere so i came to forum.if somebody help me than pls i m waiting.
Techno mode key
Cyl Count............................... : 170
ROM version............................. : 01.CSE
ROM generation.......................... : 01.CSE
Link table version...................... : 03.09.
Consolidated ROM version................ : 000100CS
ROM Modules:
ROM Firmware version.................... : 000100CS
both the heads are ok as i test head.
in sa structure test report only mod 11 is bad.cant copy it.i have sa region backup to but even in sa region there is no mod 11.i have check in same pinclite family diffrent model ,size of ata mod 11 is 210-250 kb. in my model it shows 431kb
Maxim_TS
Re: wd2500aajs-65m0a0 fw needed
Postby Maxim_TS » 01.04.13, 16:47
11.rpm
11.rar
(147.62 KiB) Downloaded 359 times
datasolution
Postby datasolution » 05.04.13, 19:30
hi maxim,thanks for replying but do you have rom and other mod with you.than pls send it to me.If i write this mod to hdd may be differ than i dont have any original mod 11 as i am unable to copy/ read this mod.
Postby AJ2008 » 09.04.13, 10:39
Write it to your HDD. Did you make copy of FW after read by ID? If surface looks ok and no damaged area I have potential method for you to make a repair. Other alternative is hotswap, so is important you make SA backup.
But try to write 11.rpm first, if successful will be much simpler :)
