WD30EZRX
alphapune
WD30EZRX
Postby alphapune » 28.01.13, 08:23
WD30EZRX
3.0 TB
initially in busy state making noise like head stuck
when i run WD utility following log
Techno mode key
Techno mode key:........................ : Techno key error; unexpected error: Drive is not ready
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
HDD Info reading........................ : HDDs RAM reading error - Device Error Detected: "VSCE VSC MODE DISABLED"
ROM version............................. : 20.1UP
ROM generation.......................... : 20.1UP
Link table version...................... : 0B.38.
Consolidated ROM version................ : 0020001U
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 283 719 (24)
ROM Firmware version.................... : 0020001U
Is it FW issue?
Re: WD30EZRX
Postby AJ2008 » 30.01.13, 14:22
SA cant be reached, but if you hear mechanical sounds when HDD tries to operate then you should seriously consider the possibility of some level of internal damage. You need to rule this out before proceeding with any additional diagnostic steps.
