Hi This WD 80GB drive had a blown motor chip and so a donor board
was used and the ROM chip transplanted. The drive now spins up,
identifies and itself properly in PC3000 UDMA (see first picture).
But the Express testshow 100% failure to read on all sectors:
I ran the SA Surface Verification and Structure Test and you can see the errors below:
From a PC3KU test of a similar drive, I see that the errors point to S.M.A.R.T. errors.
So I attached a picture of the View Smart: (oops on 3 pix allowed!?) Basically it
has only 2 lines (with Id 0) that say "unknown parameter"
I have tried to Clear Smart, but I get an error, and then the drive starts clicking!
and I think there's a timeout error:
Other S.M.A.R.T. logs................... : S.M.A.R.T. clearing error (page 06) - Drive is not ready
I need help what to do next to get the data recovered.
Thanks!
Chris Lees
London, U.K.
WD800JD probable firmware problem
- RescueDRL@gmail.com
- New user
Re: WD800JD probable firmware problem
Try to read 31,21,32 Moduels useing composite method and rewrite them into hdd
- New user
Hi Hasan. Thanks for the info. I tried exactly as you suggest.
But I get the following errors:
Any Ideas now?
BTW I was able to repair S.M.A.R.T. using WD Doctor.
and 31, 32 gives 'CRC Length' error.
Cheers, Chris
Any Ideas now?
Cheers, Chris
You have Bad sectors in SA so you have two choice
1-if you have a donor try Hot-Swap
2-if you don't have donor you can try Dir module editting you can get the info from forum WD Marvell Dir module editing
viewtopic.php?f=35&t=7181
