WD2001FASS not showing family.
Continuum
Postby Continuum » 07.12.10, 00:41
I need to turn off the heads in RAM of this drive, but it cannot detect the family.
Is this possible?
hassan
Re: WD2001FASS not showing family.
Postby hassan » 07.12.10, 08:15
What is the full model ?
WD299xx-xxxxxx
Continuum
Postby Continuum » 07.12.10, 08:39
hassan wrote:What is the full model ?
WD299xx-xxxxxx
WD2001FASS-00W2B0
hassan
Postby hassan » 07.12.10, 11:27
on the hdd labe you you will find the model
for example "MDL:WD400EB-00CPF0"
Continuum
Postby Continuum » 08.12.10, 03:22
hassan wrote:on the hdd labe you you will find the model
That is the model. It is a new 2Tb.
hassan
Postby hassan » 08.12.10, 07:03
I think the current version of PC3000 WD Marvell utility dos not support this family yet
you can try the latest WD marvell family probably can help you
Postby ACE_Admin » 18.12.10, 16:50
It is possible to figure out the family by viewing C5 module from SA.
To enter WD utility you should enter it with some of the last added families, like DragFly X , Tahoe or other families from the end of the list.
The goal is to find a family that could access the modules. Module
