ZEUS TURN OFF HEADS
ZeBong
ZEUS TURN OFF HEADS
Postby ZeBong » 28.09.09, 20:04
Hi to all,
i am try to disable some heads 2 3 with the new option.
what i am doing is this
1 - power disk
2 - it clicks 3 times them stop
3 - enter utility ( kernel mode) dont have any jumper in the disk
Techno mode key
ROM version............................. : 07.1PE
ROM generation.......................... : 07.1PE
Link table version...................... : 02.46.
Head map................................ : 0,1,2,3,4,5,6,7
Firmware version........................ : 071P?
4 - go to the menu to to RAM HEAD MAP EDITING
but appear this : 0 0 0 0 0 0 0 0
all the heads are 0, but in ACE POST, it should appear head 0 1 2 3 4 5 6 7
5 - i give enter
6 - make a soft reset , but the disk CLIK again 3 times ?
Anyone have made this work, i have head 1 and head 3 BAD.
ZeBong
Nova
Re: ZEUS TURN OFF HEADS
Postby Nova » 29.09.09, 07:16
In kernel:
Did you see the drive ID with blank S/N, Model and FW ?
