WD1600AABS-00PRA0
CarlosAdolfo
WD1600AABS-00PRA0
Postby CarlosAdolfo » 20.05.09, 17:33
Dear Friends:
I have a problem
I have a hard drive WD1600AABS-00PRA0 and a same donor.
I've completed the exchange of heads and I failed to recovering the data.
When a made this change in a clean room and with the right tools, the disc continues with the same problem
The PC3000 shows as folllow:
Techno mode key
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirActSync"
Flash Dir reading....................... : Ok
ROM version............................. : 21.8BM
ROM generation.......................... : 21.8BM
Link table version...................... : 22.5C.
Head map................................ : 0,1
Firmware version........................ : 0021008B
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Someone can give me some ideas to fix this problem? thank you
CarlosAdolfo
