Hi All friends,
Anyone know what requirements need to match for WD drive 's heads swapping ?It seems like the result is not good if just matching the model.
Any advices appreiated
Thanks You in advance
WD heads swapping-what requirements need to match?
Re: WD heads swapping-what requirements need to match?
DCM still a myth for me...
the most important is matcching the same Head mask...
The problems are alignment over WD
steven wrote:DCM still a myth for me...
I agree. As long as model and head map is same, this is what I tend to go for.
I do try matching DCM on drives pre Marvel, but as far as Marvel family goes, I also think DCM is a myth
AJ2008 wrote:steven wrote:DCM still a myth for me...
Then try for example JH or JJ series with unmatched 5 and 6 letter in DCM
for me.. if they are same family and same head mask.. I will try to change it,. WHY ??? because If nothing DO we will never know... if we try we will know....
Hi to all,
If we just change the head in a WD and dont change the PCB, we dont need to worry about the head mask.
It is in the ROM, and if we dont change the PCB that problem not appear.
The problem that i am having is sometimes the HEAD did not read the surface, dont know why maybe pre amp differents...
Please let me know if i am thinking BAD ?
