This disk when connect to the pc3kumda dont give ID
So i have to do head map to head 6 and 7.
Now i can have the ID correct and the LBA size correct.
When i enter in the DE i try to edit sector 63, but i have dark green error ECC ERROR.
I know that i have 8 heads but are using 6 heads.
What i have to do in the LBA size to see the data.
ZeBong
Techno mode key
RAM:
Cyl Count............................... : 64
SA SPT.................................. : 864
Head number reading..................... : Ok
Heads number............................ : 5
ROM:
ROM version............................. : 07.1PE
ROM generation.......................... : 07.1PE
Link table version...................... : 02.46.
Head map................................ : 0,1,2,3,4,5
Firmware version........................ : 071P?
Service area:
SA dir reading.......................... : Ok (Copy 0)
WD5000KS-55MNB0 - How to use the head map to get DATA
Re: WD5000KS-55MNB0 - How to use the head map to get DATA
You can't.
You have to swap heads.
Head map is useful for diagnosis, but now for data recover.
datalabace wrote:You can't.
Agreed on that.
Although there is much of talk about that, can somebody confirm recovery on ZEUS withouth one or more head?
