Seagate [0x000042F9]ZZZZMMMMMMMMMMMMMMMZZ message
Posted: 12.05.15, 03:55
by -BR-
I have the following problem:
Model:
ST1000DM003
Terminal message:
Boot 0x40M
Spin Up
TCC-0018[0x000042F9][0x000042F9]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWMMMMMM
Detailed description:
We received the PCB with broken seals (someone else tried to change PCB before)
It´s impossible to access terminal (CRTL+Z)
We already did ROM soldering to a DONOR PCB and the result is the same
If I use PATIENT PCB on a donor drive (fully working), same behaviour (same terminal message)
This makes me believe that the ROM is corrupted
Does anyone know if it´s possible to recover data ?
Thanks,
-BR-
Re: Seagate [0x000042F9]ZZZZMMMMMMMMMMMMMMMZZ message
Posted: 12.05.15, 03:56
by -BR-
Posting because I have disabled the e-mail notification on the post above
Posted: 12.05.15, 19:26
by digitalsupport
Check if SN in ROM matches SN on drive.
