ST2000DL003 Sector Reading Problem
Posted: 24.02.15, 11:36
by bikram
I Have ST2000DL003 Hard Disk Which Is Only 1416578304 sector reading . i will try NG list Clearinabcg, translator recovery but problem is same
HDD family detecting...
Family ID: 4F
Selected family......................... : 4F, Bogart
Model by ID............................. : ST2000DL003-9VT166
Loading default settings!
Then press OK!
Tech Key...
Requesting FW Pkg ver ........ BGC15D.CCD9.AAB600.CC98
Detecting Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 6
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
ID Len
0 12 Reserved Defect Table (SA defect table)
3 5582 Primary Defect File (P-List))
4 48 Servo Adaptive Parameter File (SAP)
6 64 Read Adaptive Parameters File (RAP)
8 4800
B 1000
C 65535 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 2357 R/W Operating Parameters (translator, etc)
39 4096
3A 4
3D 1800
3E 1800
3F 4576
40 7
41 2180
42 4096
Collecting DT Infos...
ID MemOffs Len
0 40043600 32768 Read Adaptive Parameters File (RAP)
1 40043400 512 Controller Adaptive Parameters File (CAP)
4 11000 6144 Servo Adaptive Parameter File (SAP)
40030000 13312
total 19456
A 4010366C 1024 Seek Profile
13 40114D30 1440 Dependent Zone Table for User Area
14 401152D0 120 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 4010E784 26028 Dependent Zone Group Tables for User Area
1C 4010E5F4 400 Dependent Zone Group Tables for System Area
1D 40043620 432 VBAR Configuration File
1E 400439C0 4016 Zone Format Parameters File
ID MemOffs Len
2 400437D0 496 Zone Table
40030000 13312
total 19456
6 2FC0B8 81964 Servo Flaw Table
16 40043600 32 Drive Configuration Table
17 40045C90 2016 Temperature Control Configuration
1F 401ED700 1360 RW working user preamp table
20 401EDC50 80 RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Searching volume 3 file table in RAM.... Ok
Searching volume 0 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
Test : Edit HDD ID
Writing Saved Mode Pages...
Test : Recover translator
First start
Translation "forks" list file........... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Bogart\ST2000DL003-9VT166-CC98-5YD3NBJC\Defects\TranslationForks.lba
Maximal defect chain length............. : 64
Take into account P-List................ : Yes
At ambiguity hide "left" UNC............ : Yes
Process "32 byte tail" bug.............. : Yes
Execute Reset after defect hiding....... : Yes
HDD resources backup
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Bogart\ST2000DL003-9VT166-CC98-5YD3NBJC\Data\SABackup\
Switching Autoreassign OFF...
G-List erase...
Translator regeneration...
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Start scanning...
"Fork" searching: 0 - 3907029167
Verify sectors ext error Device error detected "UNC"
"Left fork", LBA = 01416578495, pattern 0xFF
Defects hiding (P23)...
Moving defects to Slip-List...
"Fork" searching: 1416578495 - 3907029167
"Right fork", LBA = 01416578495, pattern 0x00
Translation "fork" direction detection ambiguity!
Correct it manually!
LBA : 1416578495
