ST320LT014-9YK142 (1Ah)-TCG Serial Port Disabled
drdoc
Postby drdoc » 21.02.15, 04:59
Is this drive supported or whats going on?
Terminal says its locked and entech commands dont work.
Model : ST320LT014-9YK142
Serial : W0Q01SAY
Firmware : 0001DEM7
Capacity : 298.09 GB (625 142 448)
says its a Julius1
This is a slim seagate. Sounds crashy.
Terminal gives me this:
Log shows this
HDD family detecting...
Family ID: 54
Selected family......................... : 54, Julius1
Model by ID............................. : ST320LT014-9YK142
Loading default settings!
Then press OK!
Tech Key...
En Tech err! Tech state 0x72, 0x07200200
Requesting FW Pkg ver ........ JU0888.DEM7.AA0097.0001DEM7
Detecting Phys Sct Size...
Error obtaining Phys Sect Size!
Detecting Max Head number...
Phys. heads............................. : Error
Test : Edit HDD ID
skype: wayne_horner
Alandata Data Recovery
drdoc
Re: ST320LT014-9YK142 (1Ah)-TCG Serial Port Disabled
Postby drdoc » 04.03.15, 03:31
hello????
ACE - earth to ace...
This question was posted 13 days ago with not one response.
skype: wayne_horner
drdoc
Postby drdoc » 05.03.15, 00:47
ace says not supported...
skype: wayne_horner
Postby AJ2008 » 26.03.15, 13:11
what is the problem with it, do you need access to SA on it?
drdoc
Postby drdoc » 26.03.15, 17:34
heres whats weird...
I could read all of the drive except for about 260,000 sectors about 3gb out.
but every sectors was zeros
except it had a partition table describing a 8mb partiton
and that partition had a bootblock that I had never seen at 0x3f
so I am wondering if someone tried to remove the encryption and managed to trigger and self-erase?
Or could the drive be lying to me and only showing zeros.
skype: wayne_horner
Doomer
Postby Doomer » 21.04.15, 06:51
drdoc wrote:Or could the drive be lying to me and only showing zeros.
That is a correct assumption
This a self encrypting drive and it locks out the real user partition until it validates user credentials, what you see is actually virtual user space with a small bootable partition which supposed to ask you for a user name and password once you boot. And the laptop encrypts the user password before sending it to the drive to make your life more colorful and fun :) You would need original laptop and original password to unlock the drive.
Seagate also locks you out from using vendor commands on SED drives to protect IP and increase drive's security, which is, I'm sure, you appreciate very much.
