Seagate ST3500418AS Sector Reading problem
Posted: 03.10.14, 07:26
by betty
Hai All
I have the segate 500GB with model ST3500418AS FW CC33. Problem is that I can't access total sector.It shows full capacity. It can possible smart reset, i can access terminal mode,m0,6,2,,,,,22 etc... But when i try to use translator recovery there have giving error on sector reading. Also i try to read sector through sector edit menu, i can't read the sector. error of 48bit showing... But if i use option " utility and then " transit split data" yes/no .... then press yes i can read the data....
but in DE i used the same utility... even though i can't get full data...
Any one can give any idea.... to solve the problem..
Betty
Crystal
Re: Seagate ST3500418AS Sector Reading problem
Posted: 03.10.14, 10:09
betty wrote:ST3500418AS FW CC33.......m0,6,2,,,,,22 etc...
This is the problem, translator is incomplete because it was rebuilt using slip list only and not NRG list which is also a dependency for translator to load properly. Did you save entries from NRG before you apply this command?
Posted: 04.10.14, 06:07
by betty
First Thanks AJ2008,
I had save the HDD resources. That has some module have reading problem. ie module 0027,0028,29,30,31,32,2C,2D .And it shows in terminal following message.
Starting LBA of RW Request=0001869F Length=FFFFFFFF
ProcessRWError -Read- at LBA 0001869F Sense Code=43110081
Unrecoverable Error Reported
(H) SATA Reset
SSPSaveSettings
SSPRestoreSettings
Send Status: COMRESET seen
(S) SATA Reset
Starting LBA of RW Request=0001161C Length=FFFFFFFF
ProcessRWError -Read- at LBA 0001161C Sense Code=43110081
Starting LBA of RW Request=0001161D Length=FFFFFFFF
ProcessRWError -Read- at LBA 0001161D Sense Code=43110081
Starting LBA of RW Request=0001161E Length=FFFFFFFF
ProcessRWError -Read- at LBA 0001161E Sense Code=43110081
And also i tried to recover the translation recovery proccess. But after some time it shows
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Detecting Phys Sct Size...
Start scanning...
"Fork" searching: 1055901 - 976773167
Verify sectors ext error Device error detected "UNC"
PRd: Err Rd Ph Sect E7:1:32F(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect E7:1:32F(1)! Tech state 0x72, 0x03110081
LBA : 1055901
"Fork" searching: 1055902 - 976773167
PRd: Err Rd Ph Sect E7:1:330(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect E7:1:330(1)! Tech state 0x72, 0x03110081
LBA : 1055902
"Fork" searching: 1055903 - 976773167
And One more thing is that first 5 digit sector can access. ie 99999 or 55555 . But when i try to access 6 digit it shows "48bit error"
I hope that you can help .....
Betty
Crystal
India
Posted: 05.10.14, 08:31
by betty
Hai everybody,
the same hdd have new problem... model,fw,serial is showing as it is.. but the capacity is 0 mb... Also we can access the terminal. And when we are doing" clear
Smart (N1) it shows the following message.
Init SMART Fail
LED:000000CC FAddr:0024EA75
Any body can give any idea
Betty
crystal
Posted: 05.10.14, 12:33
by pclab
I have a similar problem with a ST9500325AS.
I hear no clicks.
It's well detected, can read all resources without any problem.
But When I try to read sectors, I get Read Error 48-bit Device error detected UNC.
But sometimes the same sector can be read.
On PC3K, head test is OK, but on DDI, the head's show failures, altough I could already imaged a piece of the drive.
I have tried to clear G-List, SMART and translator regen, but the same happens.
Translator Recovery does this:
"Fork" searching: 11 - 976773167
PRd: Err Rd Ph Sect 0:0:B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:B(1)! Tech state 0x72, 0x03110081
LBA : 11
"Fork" searching: 12 - 976773167
PRd: Err Rd Ph Sect 0:0:C(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:C(1)! Tech state 0x72, 0x03110081
LBA : 12
"Fork" searching: 13 - 976773167
PRd: Err Rd Ph Sect 0:0(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0(1)! Tech state 0x72, 0x03110081
LBA : 13
"Fork" searching: 14 - 976773167
PRd: Err Rd Ph Sect 0:0:20(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:20(1)! Tech state 0x72, 0x03110081
LBA : 32
"Fork" searching: 33 - 976773167
PRd: Err Rd Ph Sect 0:0:21(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:21(1)! Tech state 0x72, 0x03110081
LBA : 33
"Fork" searching: 34 - 976773167
PRd: Err Rd Ph Sect 0:0:23(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:23(1)! Tech state 0x72, 0x03110081
LBA : 35
"Fork" searching: 36 - 976773167
PRd: Err Rd Ph Sect 0:0:24(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:24(1)! Tech state 0x72, 0x03110081
LBA : 36
"Fork" searching: 37 - 976773167
PRd: Err Rd Ph Sect 0:0:30(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:30(1)! Tech state 0x72, 0x03110081
LBA : 48
"Fork" searching: 49 - 976773167
PRd: Err Rd Ph Sect 0:0:34(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:34(1)! Tech state 0x72, 0x03110081
LBA : 52
"Fork" searching: 53 - 976773167
PRd: Err Rd Ph Sect 0:0:35(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:35(1)! Tech state 0x72, 0x03110081
LBA : 53
"Fork" searching: 54 - 976773167
PRd: Err Rd Ph Sect 0:0:36(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:36(1)! Tech state 0x72, 0x03110081
LBA : 54
"Fork" searching: 55 - 976773167
PRd: Err Rd Ph Sect 0:0:3F(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:3F(1)! Tech state 0x72, 0x03110081
LBA : 63
"Fork" searching: 64 - 976773167
PRd: Err Rd Ph Sect 0:0:40(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:40(1)! Tech state 0x72, 0x03110081
LBA : 64
If I selected the option Read/Write Options - Use utility and I can read the sectors without the UNC faillure... I can image the drive like this, but the speed is 1kb/s. It will take forever...
Any idea how to speed it up?
Posted: 06.10.14, 12:46
by betty
hai to everyone,
Still my problem is going on..... Now i found one more error message... ie When do the Smart reset.. ie N1 , i am getting the message " Init smart fail". any solution for it...
Betty
Crystal
