ST320LT009 security locked
Posted: 23.09.14, 03:49
model : ST320LT009
fw : 1002DEMA
hi
this hdd security locked.
in utility, show model, serial, firmware, capacity correctly.
i itried in utility, but can't unlock with this error.
ATTENTION! Security-locked HDD.
HDD family detecting...
Family ID: 54
Selected family......................... : 54, Julius1
Model by ID............................. : ST320LT009-9WC142
Loading default settings!
Then press OK!
Tech Key...
Error starting command "En Tech" (ABR)
Test : Reset passwords
En Tech err! Tech state 0x72, 0x07200200
and i tried ctrl+z in terminal.
show this massage.
Rst 0x10M
(P) SATA Reset
(1Ah)-TCG Serial Port Disabled
this hdd is self encrypting drive.
is it relation with this problems?
and, how can i recover this hdd?
thanks your help.
fw : 1002DEMA
hi
Family ID: 54
Then press OK!
Tech Key...
show this massage.
Rst 0x10M
(P) SATA Reset
thanks your help.
