Seagate ST2000DM001
Posted: 16.06.14, 00:32
by entec
Hi ,i have seagate ST2000DM001 with pcb 100664987 . When I connect drive to PC-3000 and turn power on it just clicks and then spins down and the terminal shows that attachment. Any ideea and short points ? thanks
Re: Seagate ST2000DM001
Posted: 16.06.14, 01:36
by entec
Here is the log of PC3000 with this hdd :
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
ResponseFrame EAC0 0051 03B4 2EC0 0008 0000 0000 0000 0F75 0000 0000 0000 0000 0000 0000 0000 59F6 1239 FFFF 2000 20F3 0000 0000 3E32 0000 3E32 0000 2247 0000 0020 001E 0007 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame E4C0 0054 03B4 2F00 0008 0000 0000 0000 0F67 0000 0000 0000 0000 0000 0000 0000 59F6 1239 FFFF 2000 20F3 0000 0000 3E32 0000 3E32 0000 007F 0000 0020 001E 0004 0000
ResponseFrame E480 0054 03B4 2F80 0008 0000 0000 0000 0F4C 0000 0000 0000 0000 0000 0000 0000 59F6 1239 FFFF 2000 20F3 0000 0000 3E32 0000 3E32 0000 007F 0000 0020 001E 0004 0000
Mention that not ID, serial and firmware ,capacity PC3000 window. sorry my english thanks
Posted: 16.06.14, 17:34
by rezafarah
if the hdd is not ID, and you have click sound, hdd head's may bad and you should change the hdd with donor hard disk.
Posted: 24.06.14, 18:22
entec wrote:FAIL Servo Op
This means Servo cant be read. Usually is some physical error with heads or surface damage. Sometimes you can reach ID and partial data with head map adjustment in ROM
Posted: 01.02.15, 09:25
by entec
I changed the hard drive heads donor and just as happens with this hard. I need all the data on the hard drive but it looks like keep solved. In this case you should try to extract partial data without a head. However, if the surface is broken there was no way to load something in RAM or ROM to be able to access all hard drive and extract all data? sorry my english
thank you
