Seagate ST2000DM001 - Recognize But Don't read any sector...
Posted: 20.05.14, 18:39
I have a Seagate HD and only remained in a busy state. I short the pins, acesss terminal and recover the translator.
Now the HDD recognizes normally and is in READY, but not read any sector.
I need to recover the data and I send below the terminal message:
Can someone help me?
Boot 0x40M
Spin Up
TCC-0022[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0022
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00000008
[RSRS] 0000
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00000001
MCMainPOR: Feature Enabled...
(DOS)STE OGHT: 0x00000000000DC973 - 0x00000000000DD0D4 - 0x00000301 - 0x0000031F Count 0052
(DOS)CMP Count 0052
(DOS)STE OGHT: 0x000000000014E525 - 0x000000000014FE74 - 0x00000301 - 0x0000031F Count 0052
(DOS)CMP Count 0052
(DOS)STE OGHT: 0x0000000000183279 - 0x0000000000184424 - 0x00000407 - 0x00000425 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000001BCCE5 - 0x00000000001BE55C - 0x00000407 - 0x00000425 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x000000000014A141 - 0x000000000014C784 - 0x00000339 - 0x00000357 Count 005B
(DOS)CMP Count 005B
(DOS)STE OGHT: 0x000000000C391BEC - 0x000000000C394536 - 0x0001C29D - 0x0001C2BB Count 0053
(DOS)CMP Count 0053
(DOS)STE OGHT: 0x000000000C391D41 - 0x000000000C39468B - 0x0001C29E - 0x0001C2BC Count 0047
(DOS)CMP Count 0047
(DOS)STE OGHT: 0x000000000C390148 - 0x000000000C392A92 - 0x0001C289 - 0x0001C2A7 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x000000000C392A93 - 0x000000000C392A92 - 0x00051E6C - 0x00051E8A Count 0062
(DOS)CMP Count 0062
(DOS)STE OGHT: 0x000000000C3907F1 - 0x000000000C39313B - 0x0001C28E - 0x0001C2AC Count 0041
(DOS)CMP Count 0041
(DOS)STE OGHT: 0x000000000014B63D - 0x000000000014DC80 - 0x0000034A - 0x00000368 Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x000000000008DEEA - 0x0000000000090283 - 0x0000018B - 0x000001A9 Count 004C
(DOS)CMP Count 004C
(DOS)STE OGHT: 0x0000000000A264F0 - 0x0000000000A28E97 - 0x00001759 - 0x00001777 Count 004B
(DOS)CMP Count 004B
(DOS)STE OGHT: 0x00000000000F30A9 - 0x00000000000F5ACC - 0x0000026D - 0x0000028B Count 0040
(DOS)CMP Count 0040
(DOS)STE OGHT: 0x000000000010C923 - 0x000000000010ECBC - 0x00000241 - 0x0000025F Count 0042
(DOS)CMP Count 0042
(DOS)STE OGHT: 0x0000000000090038 - 0x00000000000923D1 - 0x000001A8 - 0x000001C6 Count 004E
(DOS)CMP Count 004E
(DOS)STE OGHT: 0x000000000C534532 - 0x000000000C536E00 - 0x0001CDF4 - 0x0001CE12 Count 0043
(DOS)CMP Count 0043
(DOS)STE OGHT: 0x000000000C39652F - 0x000000000C398E79 - 0x0001C2D4 - 0x0001C2F2 Count 0046
(DOS)CMP Count 0046
(DOS)STE OGHT: 0x000000000006E514 - 0x000000000006E927 - 0x00000159 - 0x00000177 Count 004A
(DOS)CMP Count 004A
(DOS)STE OGHT: 0x00000000000A71E8 - 0x00000000000A97F7 - 0x00000159 - 0x00000177 Count 004A
(DOS)CMP Count 004A
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Boot 0x40M
Spin Up
Trans.
Rst 0x40M
Spin Up
TCC-0022
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 0000
[MCMTWS]
(DOS)CMP Count 0052
(DOS)CMP Count 0052
(DOS)CMP Count 0048
(DOS)CMP Count 0048
(DOS)CMP Count 005B
(DOS)CMP Count 0053
(DOS)CMP Count 0047
(DOS)CMP Count 0048
(DOS)CMP Count 0062
(DOS)CMP Count 0041
(DOS)CMP Count 0040
(DOS)CMP Count 004C
(DOS)CMP Count 004B
(DOS)CMP Count 0040
(DOS)CMP Count 0042
(DOS)CMP Count 004E
(DOS)CMP Count 0043
(DOS)CMP Count 0046
(DOS)CMP Count 004A
(DOS)CMP Count 004A
PowerState = IDLE1
PowerState = IDLE2
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
