ST31000524AS Slow terminal, no data access
Posted: 29.10.13, 13:14
I have ST31000524AS
spins up and sounds OK
When I start utility immediately after power up I can get drive ID, after that BSY DRD/DSC and no more data access.
Power down/power up in active utility gives normal terminal output and DRD/DSC
Rst 0x20M
(P) SATA Reset
There is no other terminal response i.e. terminal is dead for approx. 15 min after power up. Drive sounds/feels like it tries to read every 3 secs i.e. there is slight vibration from the drive. Any attempt to read/write or execute service command results in BSY DRD/DSC.
15-20 mins after power up terminal becomes functional - all commands work. Those 3 sec reading cycles - vibrations stop.
Heads look OK.
Head 00 Resistance 00E0
Head 01 Resistance 009D
Head 02 Resistance 00C1
Head 03 Resistance 00B1
V40 gives this
F3 T>V40
Nonresident GList D entries returned
Total entries available: D
71A90425 1 20 3CB17 0 1BF 34B48
72716027 1 20 3D50C 0 A7 88C68
729C07CB 1 20 3D752 0 2F3 97E53
729C13EC 1 20 3D755 0 8 9834B
72D3BBFC 1 20 3DA04 0 20C 3C0D4
72DD4D72 2 20 3DAB3 0 236 3C47A
735F7428 1 20 3E161 0 74 3085E
746B80E4 16 20 3EF20 0 26C 6102B
746B80FF E 20 3EF20 0 287 6471E
746B810E 2 20 3EF20 0 296 66557
746B8113 A 20 3EF20 0 29B 66F6A
746B8120 17 20 3EF20 0 2A8 689B7
746B85BE 1 20 3EF1F 0 242 7B4CC
I have tried clear SMART (N1), clear Alt list (i4,1,22) and translator (m0,2,2,,,,,22 and m0,6,2,,,,,22) - no difference.
Can't clear G-List, edit Drive ID or any other service command - always ends with BSY DRD/DSC and Drive is not ready - terminal remains active.
What can I try next?
Rst 0x20M
(P) SATA Reset
Heads look OK.
V40 gives this
F3 T>V40
