Seagate ST2000DM001-9YN164-CC4C stays Busy
Posted: 13.09.13, 08:14
Hi Guys,
I have got a ST2000DM001-9YN164-CC4C drive that wouldn't start properly and make some grunting noise as it can't find FW.
Drive was not dropped based on the customer info.
I backed up the ROM through terminal and ROM content looks fine with right serial numbers and model.
I opened the drive in a clean room and don't see any obvious damage on the heads or platters but looking under a microscope i found a tiny little bit of dirt on the HDA filter on one spot.
Do you think it is the heads?
Terminal output down here, any suggestions?
PowerState = IDLE1
PowerState = IDLE2
Boot 0x40M
Spin Up
FAIL Servo Op=0100 Resp=0007
ResponseFrame EF40 004C 03B4 3C80 0008 0000 0000 0000 0C71 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0010
FAIL Servo Op=0100 Resp=0003
ResponseFrame E900 004F 03B4 3CC0 0008 0000 0000 0000 0C62 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E8C0 004F 03B4 3CC0 0008 0000 0000 0000 0C62 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E800 004F 03B4 3C40 0008 0000 0000 0000 0C7F 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E800 004F 03B4 3C80 0008 0000 0000 0000 0C71 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E780 004F 03B4 3C40 0008 0000 0000 0000 0C7F 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E740 004F 03B4 3C40 0008 0000 0000 0000 0C7F 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E700 004F 03B4 3C40 0008 0000 0000 0000 0C7F 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E6C0 004F 03B4 3C00 0008 0000 0000 0000 0C8E 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
ResponseFrame E680 004F 03B4 3BC0 0008 0000 0000 0000 0C9D 0000 0000 0000 0000 0000 0000 0000 87CF FFEF 2416 0A17 B5C4 2874 9396 A815 8938 6C5C 3304 DC6F 12A4 880C 4FDB FB5B 0000
PowerState = IDLE1
PowerState = IDLE2
Boot 0x40M
Spin Up
