head locked on platter
Posted: 06.09.13, 21:56
dear guru accept my ragards
here i have a hdd ( seagate 2.5" sata ) which it doesn't spin up bcoz its heads are parked on platters not in their parking .
after i corrected the problem ( i did it very well ) and i connected the hdd to pc3000 , it spins up but after few seconds it spins down , DRD and DSC registers light up
when i enter seagate window it shows me the HDD model and serial number but the firmware is wrong and the capacity isnot recognized .
i changed the whole HDA ( maybe it was not needed , was it ???? )
but after that job the condition is the same as before i did it .
any suggestions to solve this problem ?
these are all notes in seagate window:
HDD family detecting ...
Family ID : 3C
selected family .......: 3C, Wyatt
Model by Id ....... : ST9500325AS
loading default settings !
use the option dialog to review and save utility settings .
Then press OK !
Family Default Settings loading !
Tech Key ...
Drive not ready
Access violation at address 4004B3C in module 'Vc150.bpl' . read of address 53203A18
Family ID : 3C
Then press OK !
Tech Key ...
Drive not ready
