unreadable sectors on seagate st2000dl001
Posted: 05.08.13, 12:00
by farjad
I have a seagate st2000dl001 , and Firmware CC98, When i view sectors after 2000000 i got the unreadable sectors,
Anyone can help in this,
best reg.
gh. farjad
Re: unreadable sectors on seagate st2000dl001
Posted: 05.08.13, 13:05
Did you rebuild translator before trying to get access?
Posted: 05.08.13, 13:52
by farjad
no i dont rebuild translator
Posted: 05.08.13, 13:54
Probably someone has rebuilt translator and NRG is not right, or it has some level of pending bug. Do you see any information in Terminal field?
Posted: 06.08.13, 11:11
by farjad
No, it`s empty
Posted: 06.08.13, 11:41
You are sure there is no terminal output at all? :?:
Posted: 06.08.13, 11:49
by farjad
Yes of course.
Posted: 06.08.13, 12:03
But you get "T>" after pressing CTRL+Z?
Posted: 06.08.13, 12:18
by farjad
thanks, that`s write
the massege is
ASCII Diag mode
F3 T>
Spinning Down
Spin Down Complete
Elapsed Time 14.516 secs
Delaying 5000 msec
Jumping to Power On Resetÿ
Rst 0x20M
(P) SATA Reset
RAW OFF
PASS
Posted: 06.08.13, 12:45
With terminal connected, at your task in DE select 'Work with active utility' then select 'No' at the next prompt. Now try to read sectors .
Posted: 06.08.13, 13:23
by farjad
Please Tell us more about it ( at your task in DE select 'Work with active utility' ) or how do it?
Posted: 06.08.13, 14:04
Select 'Task Parameters' -> 'Command to Read' -> 'Read from Active PC3000 utiltiy'.
Posted: 23.08.13, 16:58
by Nick_TS
Try to increase Terminal timeout.
