ST1000DM003 no respond to Crtl+Z
Posted: 17.02.13, 18:34
by ray1006
Hello everybody,
I have a problem with some HDD that do not respond to the terminal command and when you hit Ctrl + Z they do not show "F3 T" , for example I have one "ST1000DM003 ROHS" that it has Busy Problem and when you enter Ctrl + Z in Terminal mode it show " 9 ".
1- what can I do for some HDD that do not respond to Ctrl+Z?
2- what can I do for new HDD like above (ROHS) or LP or green Seagate?
I am waiting for all of you
with Best regards
Re: ST1000DM003 no respond to Crtl+Z
Posted: 25.02.13, 13:36
by Winchester
Have you tried shorting the read channel?
Posted: 28.02.13, 06:36
by ray1006
Hi thank you for your respond. yes I did it ,but not swap PCB nor Short pin make sence on those HDD. I do not know why.
Posted: 15.04.13, 19:33
by rms620
I have too many HDDs (ST1000DL002 and STDM002) with same problem.
Posted: 25.06.14, 18:31
by Alexii
I had a similar situation with a 3TB seagate grenada. CTRL Z gave me a 9. It ended up being a problem with terminal adapter. My terminal is version 1 , newer PC USB TERMINAL 2 worked with it fine.
Posted: 09.07.15, 14:09
by betty
all of you,
I have also same problem.. Can u tell me Short-Pin point of this HDD
Betty
Crystal
Posted: 10.07.15, 03:17
by betty
Hello to all,
I do the short-pin the point and got the following messages in terminal
Spin Up[LBA=0x000042F9]N01010C10o0o0o0o0o0o0o0o0[LBA=0x000042F9]NO1111102010C10o0o0o0o0o0o0o0o01111102010C20o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111102010C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01111101020C10o0o0o0o0o0o0o0o01[LBA=0x00066E3B]N02010C10o0o0o0o0o0o0o0o0[LBA=0x00066E3B]NO1111102020C10o0o0o0o0o0o0o0o01111101020C10o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111102010C20o0o0o0o0o0o0o0o01111102020C20o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01[LBA=0x0000831D]N01010C20o0o0o0o0o0o0o0o0[LBA=0x0000831D]NO1111101020C10o0o0o0o0o0o0o0o01111102010C20o0o0o0o0o0o0o0o01111101020C20o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111102020C10o0o0o0o0o0o0o0o01111101010C20o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01[LBA=0x0006AE5F]N02020C10o0o0o0o0o0o0o0o0[LBA=0x0006AE5F]NO1111101010C20o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111102010C10o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01111101010C20o0o0o0o0o0o0o0o01111101010C10o0o0o0o0o0o0o0o01
SimError - Remaining in BootFW
Perform a double download without a power cycle
What is the meaning of "SimError" & Perform a double download without a power cycle.
betty
crystal
Posted: 19.07.15, 00:03
by Pepe
Sorry to say, but you guys are cutting wood here.
Seems you heard about some tricks and try to apply them without having an idea how it works and in what circumstances it can be used.
Drive doesn't work? Ah, let's just short some points. Still does not work? Let's regenerate the translator... (do we know what it is? No. But who cares...)
This is not Data Recovery.
And since this forum is cut open, probably no valuable info will be shared here anymore...
Posted: 20.07.15, 21:52
Pepe wrote:Sorry to say, but you guys are cutting wood here.
Well,
I Wonder Why They Split Nand Flash Forum And This One Seperate First .And Why on Earth They Make This Open Now .You Pay So Many Dollars For Free Information .This is Stupidity .If We All Raise Our Opinion They Might Change This Approach .If They Are Feeling The Heat Of Competition Why Not Lower The Pricing of The Tool
