Seeking Solution: ST2000DL003 - BSY AND PCB alone not answar
Posted: 24.10.12, 20:39
Hi guys.
1 - I have a Seagate ST2000DL003, the hdd makes the SERVO (is possible to listen), this hdd stay busy all the time.
2 - If I isolate the motor, the terminal simply do not respond
The Terminal:
MC Internal LPC Process
FAIL Op=0900 Resp=0005
(P) SATA Reset
SIM Error 1009
RW Error 00000080
User Data Base 00991B20
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A58C 4011869C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 000022AC
[RSRS] 1EFE
Reconstruction: Completed 0: MCMT Was Valid, HeadPtr was unwritten
Rst 0x40M
LED:000000BD FAddr:00005652
Img of PCB:
The Terminal:
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
[RSRS] 1EFE
Rst 0x40M
Img of PCB:
