ST3500418AS - Security-locked HDD
Posted: 24.08.12, 10:41
by Gelkin.net
Model : ST3500418AS
Serial : 9VM8ANHP
Firmware : CC38
Capacity : 465,76 GB (976 773 168)
Security-locked HDD log output on startup is:-
ATTENTION! Security-locked HDD.
Tech Key...
Error starting command "En Tech" (ABR)
Drive is identified correctly.
Then attempting to unlock drive with this option:
Tools -> HDD -> HDD Security Subsystem -> Open HDD
The Opening HDD screen pops up. I do not modify any parameters, I just press OK.
I then get the error:
Security unlock error: Device error detected "ABR"
ABR = Automatic Baud Rate... right?
I changed the COM port baud rate, but it made no difference to the error reponse.
How do I unlock this drive?
Re: ST3500418AS - Security-locked HDD
Posted: 24.08.12, 11:24
by Gelkin.net
I managed to solve the case by starting the HDD lock 000CC shorting pins solution.
I only did the shorting of the pins. The drive did not stop but was ready. I held the short on the pins until an error_write message appeared on the terminal output.
Then I cancelled the HDD lock solution. Exited the seagate utility. Power off.
Power on, restart seagate utility. Drive started up unlocked and in good condition.
Replicated this solution on 4 different (same model) drives. Solution worked fine.
Case closed ;)
Posted: 25.08.12, 03:03
by 300ddr
Thanks for sharing your solution!
