Seagate St 3160811AS
Posted: 14.08.12, 19:09
by Nadpc3k
I have seagte st3160811As ,,... very very slow in DE ... I alrady change the HDA and pcb but same thing. still slow and it gives these error in terminal ... any help or clue will help me...
Read Ver Failure!
DiskAccess ReadSector EC=43 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 15cf0.00.022b
AT Er 00 Nwt Er 43 RdWr 01d95.00.0003
ATA St 50 Er 00 Op ec a,0000/0/00,01 00 00
Niwot: 9ff79ff7 b6 9ff79ff7.1.6b7 0000 005f 0000 0000
$$Switch to full int.
AM Reacquired
(to03322,01772,0000,01,74)Switch to full int.
AM Reacquired
(to01772,01328,F649,01,74)$$Switch to full int.
AM Reacquired
DiskAccess ReadSector EC=15 at 001d95.00.0003
Re: Seagate St 3160811AS
Posted: 16.08.12, 12:44
by ACE_Admin
It is Barracuda 7200.9
AM Reacquired = Address Marker Reacquired
This happens when drive has dirty heads/broken heads or there are problems with logic board.
For 7200.9 dirty heads are much possible, so you can carefully wash them with clean isopropyl spirit.
Also, try creating a loader and use it, since there is a solution for "Failed sys sect. write! Nwt Er 00 RdWr 15cf0.00.022b" error.
