SEAGATE ST2000DL003 BSY NEED Modules and rom
Posted: 15.06.12, 15:57
by ADR
Hi I need modules and rom for SEAGATE ST2000DL003 F/W CC32 SITE: SU DATE:11396 P/N 9VT166-301
Any one can HELP??? :)
Re: SEAGATE ST2000DL003 BSY NEED Modules and rom
Posted: 18.01.13, 12:51
by Imnew
I have a HDD SEAGATE ST2000DL003 F/W CC32 SITE: WU -:11396 P/N 9VT166-301
The site code is different. Will it help you
Posted: 18.01.13, 12:53
by Imnew
Site Code is WU only
Posted: 11.03.13, 19:27
by datasolution
sorry body its too late but have you overcome your problem.are you able to see cp,dt and modules.Actually i have same drive after getting translator regeneration power off and on drive is becoming ready as well showing all info in drive id but unable to see DT,FW MOD,CPs etc.so result is when i do anything drive again goes to busy and terminal is like this.So finally i am unable to recover data.If you had same problem and get successed pls inform me.with thanks.
[9:52:53 PM] datasolution 1998: [6:04 PM] datasolution 1998:
<<< MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011A624 40118734
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 00000000
[RSRS] 0000
Rst 0x40M
MC Internal LPC Process
LED:000000BD FAddr:00006220
my drive detail is as follows: st2000dl003 fw:cc32 sitecode:wu date:12115p/n:9vt166-301
Posted: 12.03.13, 09:27
Why do you need modules for BSY problem?
@Datasolution , you need to disable any pending or relocation actions via HDD ID menu. If this is not accessible you need do it via terminal window
Posted: 09.04.13, 16:04
by labtech
AJ2008 wrote:You need to disable any pending or relocation actions via HDD ID menu. If this is not accessible you need do it via terminal window
Please, how can it be done in terminal?
Posted: 11.05.13, 18:27
by datasolution
AJ2008 wrote:Why do you need modules for BSY problem?
sir pls can u tell me how do i do it with terminal as i cant access HDD ID EDIT with clicking option menu As i am unable to see cprom,dt ,mod etc.only drive id i can see.And one more thing sir if i can see nrg list [V40] in terminal how do empty or clear.
thanks for reply.
