problem with ST500DM002 and ST1000DL002 Seagat
Posted: 30.05.12, 13:32
by rms620
I have hards model "ST500DM002 and ST1000DL002" that when i connect these to pc3000 only BSY is ON and CTRL+Z doesn't work in seagate utility .i wait one houre or more for ready state but unfortunately only BSY is on continous and CTRL+Z doesn't work.Too many hards from these models are brought with common problem for recovery and repair.
when i switch power off and on ST500DM002,i see almost following terminal log :
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 0099DAD8 00000000 00133B5B 00000000 00000000
MC 00000000 00989980 00000000 00131330 00000000 00000000
MSP 00996860 00000A68 00132D0C 0000014D 000007D4 00000001
User Partition 0099DAD8 00133B5B 000007C9 00000001
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DBEBC 060DA1A8
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 000763C7
[RSRS] 14F5 DiscLba 000B75FC RW_RTL FFFFFFFF
Reconstruction: Completed 1:
LED:000000BD FAddr:00009E13
and so when i switch power on and off ST1000DL002, i see following log terminal:
Rst 0x20M
(P) SATA Reset
User Data Base 00991088
MCMainPOR: Start:
MC Seg Disc and Cache Nodes: 4011A624 40118734
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 0001EC90
[RSRS] 172E
ProcessRWError -Read- at LBA 000CADBB Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000CADBB!
[SW] 0002
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
ReadFooters (Forward): Segment 172F StartLBA 00656DA0 Starting Footer LBA 00657110
SeqNum 0001EC92 TotalUserBlocks 0328
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 0001EC92 5D33DD33
Reconstruction: ProcessIncompletelyWrittenSegment
Reconstruction: ProcInCmptSeg: OverlapDetected: With previous Add/Rem
Reconstruction: Last Chance
Rst 0x20M
LED:000000BD FAddr:00007E05
what do u think about it?please help me
Re: problem with ST500DM002 and ST1000DL002 Seagat
Posted: 17.08.12, 16:44
by tea
ME TOO
ST3000DM001
Picture 17.jpg (348.17 KiB) Viewed 8182 times
Posted: 02.11.12, 18:26
by avenger-fr
I have a similar case ... ST1500DL003
BSY but sounds OK and in terminal (my disk have some diferences with your's but result is the same : LED BD !) :
Rst 0x40M
(P) SATA Reset
User Data Base 009915A8
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00004CEA
[RSRS] 22BC
ProcessRWError -Read- at LBA 0012FEE5 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0012FEE5!
ReadFooters (Forward): Segment 22BC StartLBA 0097F680 Starting Footer LBA 0097F8D8
SeqNum 00004CEB TotalUserBlocks 0228
Footer Status = 0001
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 00004CEB FFFFFFFF
Adds LBA/Len
005E0047/0008 005F24CF/0008 00600C1F/0008 00600EDF/0008 00600FDF/0008 006010FF/0008 00601117/0008 0060119F/0008 00601227/0008 0060127F/0008 0060128F/0010 006012A7/0008 00601317/0008 00601397/0008 006013E7/0008 006014AF/0008 0060153F/0008 00601577/0008 006015B7/0008 006015E7/0008 0060160F/0008 006016E7/0018 0060183F/0008 006018E7/0010 006019AF/0008 00601A17/0008 00601C47/0010 00601C5F/0008 00601EC7/0008 0060261F/0008 0060271F/0008 00602C1F/0008 00602D4F/0008 00602F77/0008 0060494F/0008 00604F57/0008 00604FF7/0008 0060500F/0008 0060509F/0008 006050FF/0008 006078AF/0008 00607A57/0008 00607DEF/0010 00608FFF/0008 0060A62F/0008 0060A8FF/0008 0060BABF/0008 0060BCE7/0008 0060BE5F/0008 0060BE6F/0008 0060BECF/0008 0060C09F/0008 0060C12F/0008 00619A6F/0008 00619B07/0008 2C8B092F/0010 2C8B099F/0010 2C8B0A1F/0010 2C8B0B1F/0010
Add Count 0000003B
Rems LBA/Len
Rst 0x40M
Anybody have a suggest to make ?
Posted: 15.04.13, 19:23
by rms620
Please update me about this problem.
Posted: 26.11.14, 17:06
by Alexii
Interested in this as well
