ST2000DL003 can recognize but can't read data.
Posted: 20.04.12, 04:29
Hi.
i have ST2000DL003(barracuda LP or Green).
it's like F3 series HDD lock.
sounds like ready state but can't recognize.
so i tried solution for HDD lock.
but can't resolve.
after pcb short method hdd can recognize.
i can see Model, Serial, Firmware, Capacity on utility.
but can't access SA, data area.
i tried smart clear, g-list clear, translator regenerate.
but can't resolve this case.
it's terminal massage after power on.
Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
User Data Base 00991A70
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011985C 4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00004F5E
[RSRS] 1331
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
0000251F 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
it's terminal massage while smart clear, g-list clear, translator regenerate.
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
MCInitialize: Start: Buffer Words VBM: 00000210
MCMainPOR: EXCEPTION: MC Init Fail. Feature disabled.
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = E59FF018
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000F018
MCMainPOR: MCStateFlags = 00000000
MCMainPOR: EXCEPTION: POR Failed General
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>i4,1,22
F3 T>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>m0,6,2,,,,,22
Max Wr Retries = 0D, Max Rd Retries = 0D, Max Iterations = 01, Max Certify Rewrite Retries = 29EC
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
LED:000000BD FAddr:0000602B
LED:00000067 FAddr:00000298
it's result of check heads.
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>/7
F3 7>X
Head 00 Resistance 014B
Head 01 Resistance 0113
Head 02 Resistance 0134
Head 03 Resistance 00FD
Head 04 Resistance 0132
Head 05 Resistance 013A
F3 7>
Anyone knows way for this case?
but can't resolve.
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 1331
0000251F 00000000
[MCMTWS]
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/1
F3 1>N1
F3 1>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>i4,1,22
F3 T>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>m0,6,2,,,,,22
F3 T>
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
Rst 0x40M
(P) SATA Reset
SIM Error 1009
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
ASCII Diag mode
F3 T>/7
F3 7>X
F3 7>
