7200.12 CC66 ST3500418AS
Posted: 14.03.12, 23:56
Drive spins, sounds normal, immediately:
Seen this a few times before, typically just regen translator and we're good to go, not on this guy.
Regen translator runs and completes without error. Still BSY in terminal with same error message.
Cleared GLIST to no effect and without error. Regen'd, still no joy.
Trying to run N1 command to clear smart gives a
BUT if I run the N1 command immediately after a regen without killing power it actually says it cleared the SMARTs without error. But even after successfully clearing the Smart it still gives the No HOST FIS and is a brick.
This is a very important customer of mine in a real pickle. First time poster here. Any ideas?
Code: Select all
Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002A185
Code: Select all
Init SMART Fail
LED:000000CC FAddr:0024E59
Code: Select all
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 6
Product FamilyId: 3F, MemberId: 05
HDA SN: 5VM9RMQA, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 3A386030, PreampType: 73 23
PCBA SN: 0000E035A48K, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Package Version: PH0G2D.CCD6.EC016V., Package P/N: 100591807, Package Builder ID: AT,
Package Build Date: 09/11/2009, Package Build Time: 17:03:00, Package CFW Version: PH0G.CCD6.00203193.AT00,
Package SFW1 Version: D24D, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 09111703, CustomerRel: CC66, Changelist: 00203193, ProdType: PH0G.CCD6, Date: 09/11/2009, Time: 170300, UserId: 00236537
Servo FW Rev: D24D
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
Features:
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled This is a very important customer of mine in a real pickle. First time poster here. Any ideas?
