ST980411ASG DE17 MB () cant edit id
Posted: 23.02.12, 07:22
Model : ST980411ASG
Serial : 5TF06XNH
Firmware : DE17
Capacity : MB ()
same drive as other post.
ok I found some issues
I tried the led00cc fix and it shows some bad mods 13, 19 2a 2b 35
Wahst the solution?
Heres the log.
increased timeout to 60 seconds..
Test : Solution for problem "HDD Lock (LED: 000000CC)"
Spin Up...
Collecting Sys Files Infos...
ID Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List))
4 12 Servo Adaptive Parameter File (SAP)
6 66 Read Adaptive Parameters File (RAP)
8 4800
9 1 SMART Configuration File
A 2259 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
2B 1160 R/W Operating Parameters (translator, etc)
33 4576
35 26 SMART Data
Collecting ROM Info...
Collecting ROM Info completed
Test : HDD resources backup
Folder: E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST980411ASG-DE17-5TF06XNH\Data\SABackup\
Reading ROM to profile folder
Folder: E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST980411ASG-DE17-5TF06XNH\Data\SABackup\ROM\
Result............................................ : Ok
Reading DT to profile folder
Folder: E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST980411ASG-DE17-5TF06XNH\Data\SABackup\CPDir\
DT 0015 (Flash), BGMS File (Directed Offline Scan).................... : Ok
DT reading process completed
Folder: E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST980411ASG-DE17-5TF06XNH\Data\SABackup\ModDir\
Module 0000, Reserved Defect Table (SA defect table).................. : Ok
Module 0001, Drive Information File (DIF)............................. : Ok
Module 0002, Performance Parameter File (PPF)......................... : Ok
Module 0003, Primary Defect File (P-List))............................ : Ok
Module 0004, Servo Adaptive Parameter File (SAP)...................... : Ok
Module 0005, Manufacturing Information File (MIF)..................... : Ok
Module 0006, Read Adaptive Parameters File (RAP)...................... : Ok
Module 0007, Controller Adaptive Parameters File (CAP)................ : Ok
Module 0008........................................................... : Ok
Module 0009, SMART Configuration File................................. : Ok
Module 000A, SMART Data File.......................................... : Ok
Module 000B........................................................... : Ok
Module 000C, Serial Port Test Results File (Self Scan Log)............ : Ok
Module 000D........................................................... : Ok
Module 000E, Data Integrity Check (DIC), HEAD 0....................... : Ok
Module 000F, DIC Dummy File........................................... : Ok
Module 0013, Disc Registry File (settings, security, etc)............. : Error <<<<<<<<<<<<
Error : Rq Rd Sys File part ID 13, Offs 0x0 err! Tech state 0x72, 0x04440000
Module 0015, BGMS File (Directed Offline Scan)........................ : Ok
Module 0016........................................................... : Ok
Module 0017........................................................... : Ok
Module 0019, Log File................................................. : Error <<<<<<<<<
Error : Rq Rd Sys File part ID 19, Offs 0x0 err! Tech state 0x72, 0x04440000
Module 001A, Log File................................................. : Ok
Module 001B, Log File................................................. : Ok
Module 001C........................................................... : Ok
Module 001D, Physical Overlay File 0.................................. : Ok
Module 001E, Physical Overlay File 1.................................. : Ok
Module 001F, Physical Overlay File 2.................................. : Ok
Module 0022, Drive Self Test (DST), Head 0............................ : Ok
Module 0023, Drive Self Test (DST), Head 1............................ : Ok
Module 002A, Saved Mode Pages (HDD settings).......................... : Error <<<<<<<<
Error : Rq Rd Sys File part ID 2A, Offs 0x0 err! Tech state 0x72, 0x04440000
Module 002B, R/W Operating Parameters (translator, etc)............... : Error <<<<<<<<<<<<<<<
Error : Rq Rd Sys File part ID 2B, Offs 0x0 err! Tech state 0x72, 0x04440000
Module 002C, Data Integrity Check (DIC), HEAD 1....................... : Ok
Module 0033........................................................... : Ok
Module 0034, Packed CONGEN XML definition............................. : Ok
Module 0035, SMART Data............................................... : Error <<<<<<<<<<<< 35
Error : Rq Rd Sys File part ID 35, Offs 0x0 err! Tech state 0x72, 0x04440000
Reading ID pages list...
Reading ID pages...
ID Page 00............................................................ : Ok
ID Page 01............................................................ : Ok
ID Page 02............................................................ : Ok
ID Page 03............................................................ : Ok
ID Page 04............................................................ : Ok
ID Page 08............................................................ : Ok
ID Page 09............................................................ : Ok
ID Page 0A............................................................ : Ok
ID Page 0B............................................................ : Ok
ID Page 0C............................................................ : Ok
ID Page 0D............................................................ : Ok
ID Page 0E............................................................ : Ok
ID Page 0F............................................................ : Ok
Backup RW params file...
Serial : 5TF06XNH
Firmware : DE17
Capacity : MB ()
Wahst the solution?
Heres the log.
Spin Up...
ID Len
8 4800
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
Reading ID pages...
