seagate recover translator questions
Posted: 08.02.12, 03:05
by drdoc
I have a seagate which I am having trouble getting translator recovery
working
I dont understand the directions on the website viewtopic.php?f=34&t=7316
the drive has has sectors starting at 48e
They were flaky up to about 1200
The instructions say to read sectors around the defect.
The good secotrs before 1166 are all zeros - because the data is all zeros.
It says ambiguity and ended with lba 1173
Here are my tests around the area.
This shows the 3 types of reads : Normal, utility-no-errors and utility-yes-errors
D means I got Data no error
X means I got read error
0 means I get all zeros
? means I got mostly zeros - these change randomly sometimes they read ll zeros, sometimes they get different patterns of mom-zeros.
So whats going on? How do I fix this ?
sector
1165 D <<<<<<<<<< 1165 and before read fine Data
1166 X 0 ? <<< heres the 3 read types normal=error (X) utility-NO=zeros Utility-yes=? mostly zeros, changes
1167 X 0 0
1168 X 0 ?
1169 X 0 ?
1170 X 0 ?
1171 X X ?
1172 X 0 ?
1173 X 0 0 <<<< translator ambiguity gives up here.
1174 X 0 0
1175 X 0 ?
1176 X 0 0
1177 X 0 ?
1178 X 0 0
1179 X 0 9
1180 X 0 ?
1181 X 0 0
1182 X 0 0
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 4 0
48E 34 34 0 0 48E 0 0 4C2 9897E 4C2 <<<< 48e and 48f are overlapping ??
48F 24 58 0 0 48F 0 0 4E7 9D3A3 4E7
86E 5 5D 0 0 86E 0 0 8CB 11A002 8CB
Model : ST31000528AS
Serial : 9VP38ZJA
Firmware : CC38
Capacity : 931.51 GB (1 953 525 168)
Test : Hiding defects to Slip-List
Detecting defects hiding cmd type...
G-List erase...
Defects hiding (P)...
Moving defects to Slip-List...
Completed!
Test : Recover translator
Start from LBA.................................... : 1187
Translation "forks" list file..................... : E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST31000528AS-CC38-9VP38ZJA\Defects\TranslationForks.lba
Maximal defect chain length....................... : 64
Take into account P-List.......................... : No
At ambiguity hide "left" UNC...................... : No
HDD ID reading...
G-List erase...
Detecting Phys Sct Size...
Start scanning...
"Fork" searching: 1187 - 1953525167
Verification error 48-bit (UNC)
"Right fork", LBA = 00000001187, pattern 0x00
Translator regeneration...
"Left fork", LBA = 00000001186, pattern 0x00
"Fork" searching: 1186 - 1953525167
"Right fork", LBA = 00000001186, pattern 0x00
"Left fork", LBA = 00000001185, pattern 0x00
"Fork" searching: 1185 - 1953525167
"Right fork", LBA = 00000001185, pattern 0x00
"Left fork", LBA = 00000001184, pattern 0x00
"Fork" searching: 1184 - 1953525167
"Right fork", LBA = 00000001184, pattern 0x00
"Left fork", LBA = 00000001183, pattern 0x00
"Fork" searching: 1183 - 1953525167
"Right fork", LBA = 00000001183, pattern 0x00
"Left fork", LBA = 00000001182, pattern 0x00
"Fork" searching: 1182 - 1953525167
"Right fork", LBA = 00000001182, pattern 0x00
"Left fork", LBA = 00000001181, pattern 0x00
"Fork" searching: 1181 - 1953525167
"Right fork", LBA = 00000001181, pattern 0x00
"Left fork", LBA = 00000001180, pattern 0x00
"Fork" searching: 1180 - 1953525167
"Right fork", LBA = 00000001180, pattern 0x00
"Left fork", LBA = 00000001179, pattern 0x00
"Fork" searching: 1179 - 1953525167
"Right fork", LBA = 00000001179, pattern 0x00
"Left fork", LBA = 00000001178, pattern 0x00
"Fork" searching: 1178 - 1953525167
"Right fork", LBA = 00000001178, pattern 0x00
"Left fork", LBA = 00000001177, pattern 0x00
"Fork" searching: 1177 - 1953525167
"Right fork", LBA = 00000001177, pattern 0x00
"Left fork", LBA = 00000001176, pattern 0x00
"Fork" searching: 1176 - 1953525167
"Right fork", LBA = 00000001176, pattern 0x00
"Left fork", LBA = 00000001175, pattern 0x00
"Fork" searching: 1175 - 1953525167
"Right fork", LBA = 00000001175, pattern 0x00
"Left fork", LBA = 00000001174, pattern 0x00
"Fork" searching: 1174 - 1953525167
"Right fork", LBA = 00000001174, pattern 0x00
"Left fork", LBA = 00000001173, pattern 0x00
"Fork" searching: 1173 - 1953525167
"Right fork", LBA = 00000001173, pattern 0x00
Translation "fork" direction detection ambiguity!
Correct it manually!
LBA : 1173
Drive not ready
PRd: Err Rd Ph Sect 0:0:4BE(1)! Tech state 0x72, 0x03110081
PRd: Err Rd Ph Sect 0:0:4BC(1)! Tech state 0x72, 0x03110081
PRd: Err Rd Ph Sect 0:0:4BF(1)! Tech state 0x72, 0x03110081
PRd: Err Rd Ph Sect 0:0:4BD(1)! Tech state 0x72, 0x03110081
PRd: Err Rd Ph Sect 0:0:4C1(1)! Tech state 0x72, 0x03110081
Re: seagate recover translator questions
Posted: 08.02.12, 22:33
by drdoc
ok so I tried rerunning tranlator recover with forced left fork option.
It starts with this slip list (just the first few..)
F3 T>V1
48E 59 59 0 0 48E 0 0 4E7 9D3A3 4E7
86D 5 5E 0 0 86D 0 0 8CB 11A002 8CB
26098 2E 8C 24 1 A3 0 24 D1 2A2AE 26124
269F9 A32 ABE 22 1 0 0 22 0 8F59C 274B7
Then I run the translaotr recovery and after the slip list is this...
It created an overlap.
I wonder if there is a saved defect list somewhere that it is merging in...
F3 T>V1
48E 3 3 0 0 48E 0 0 491 92713 491
48F 3 6 0 0 48F 0 0 495 92F40 495
493 1 7 0 0 493 0 0 49A 9391D 49A
494 94 9B 0 0 494 0 0 52F A63E3 52F
82B 5 A0 0 0 82B 0 0 8CB 11A002 8CB
Heres the full translator recovery log
Anyone have any ideas?
List index out of bounds (-1)
Test : Translator regeneration
Result............................................ : Error
Error : Error starting command "En Tech" (Drive is not ready)
First start
At ambiguity hide "left" UNC...................... : Yes
HDD resources backup
Folder: E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST31000528AS-CC38-9VP38ZJA\Data\SABackup\
Backup of service information completed
Switching Autoreassign OFF...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
G-List erase...
Result............................................ : Ok
HDD ID reading...
G-List erase...
Start scanning...
"Fork" searching: 0 - 1953525167
"Right fork", LBA = 00000001166, pattern 0x00
"Fork" searching: 1166 - 1953525167
PRd: Err Rd Ph Sect 0:0:491(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:491(1)! Tech state 0x72, 0x03110081
LBA : 1166
"Fork" searching: 1167 - 1953525167
PRd: Err Rd Ph Sect 0:0:492(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:492(1)! Tech state 0x72, 0x03110081
LBA : 1167
"Fork" searching: 1168 - 1953525167
PRd: Err Rd Ph Sect 0:0:493(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:493(1)! Tech state 0x72, 0x03110081
LBA : 1168
"Fork" searching: 1169 - 1953525167
"Left fork", LBA = 00000001168, Forced
"Left fork", LBA = 00000001167, Forced
"Right fork", LBA = 00000001167, pattern 0x00
PRd: Err Rd Ph Sect 0:0:495(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:495(1)! Tech state 0x72, 0x03110081
LBA : 1167
PRd: Err Rd Ph Sect 0:0:496(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:496(1)! Tech state 0x72, 0x03110081
LBA : 1168
PRd: Err Rd Ph Sect 0:0:497(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:497(1)! Tech state 0x72, 0x03110081
LBA : 1169
"Fork" searching: 1170 - 1953525167
PRd: Err Rd Ph Sect 0:0:498(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:498(1)! Tech state 0x72, 0x03110081
LBA : 1170
"Fork" searching: 1171 - 1953525167
"Right fork", LBA = 00000001171, pattern 0x00
PRd: Err Rd Ph Sect 0:0:49A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:49A(1)! Tech state 0x72, 0x03110081
LBA : 1171
"Fork" searching: 1172 - 1953525167
PRd: Err Rd Ph Sect 0:0:49B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:49B(1)! Tech state 0x72, 0x03110081
LBA : 1172
PRd: Err Rd Ph Sect 0:0:49C(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:49C(1)! Tech state 0x72, 0x03110081
LBA : 1173
PRd: Err Rd Ph Sect 0:0:49E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:49E(1)! Tech state 0x72, 0x03110081
LBA : 1174
PRd: Err Rd Ph Sect 0:0:49F(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:49F(1)! Tech state 0x72, 0x03110081
LBA : 1175
PRd: Err Rd Ph Sect 0:0:4A0(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A0(1)! Tech state 0x72, 0x03110081
LBA : 1176
PRd: Err Rd Ph Sect 0:0:4A1(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A1(1)! Tech state 0x72, 0x03110081
LBA : 1177
"Left fork", LBA = 00000001177, Forced
PRd: Err Rd Ph Sect 0:0:4A3(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A3(1)! Tech state 0x72, 0x03110081
LBA : 1177
PRd: Err Rd Ph Sect 0:0:4A4(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A4(1)! Tech state 0x72, 0x03110081
LBA : 1178
PRd: Err Rd Ph Sect 0:0:4A5(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A5(1)! Tech state 0x72, 0x03110081
LBA : 1179
PRd: Err Rd Ph Sect 0:0:4A6(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A6(1)! Tech state 0x72, 0x03110081
LBA : 1180
PRd: Err Rd Ph Sect 0:0:4A7(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A7(1)! Tech state 0x72, 0x03110081
LBA : 1181
PRd: Err Rd Ph Sect 0:0:4A8(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A8(1)! Tech state 0x72, 0x03110081
LBA : 1182
PRd: Err Rd Ph Sect 0:0:4A9(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4A9(1)! Tech state 0x72, 0x03110081
LBA : 1183
PRd: Err Rd Ph Sect 0:0:4AA(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4AA(1)! Tech state 0x72, 0x03110081
LBA : 1184
PRd: Err Rd Ph Sect 0:0:4AB(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4AB(1)! Tech state 0x72, 0x03110081
LBA : 1185
"Left fork", LBA = 00000001185, Forced
PRd: Err Rd Ph Sect 0:0:4AF(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 0:0:4AF(1)! Tech state 0x72, 0x03110081
LBA : 1184
"Left fork", LBA = 00000001183, Forced
"Left fork", LBA = 00000001182, Forced
"Left fork", LBA = 00000001180, Forced
"Left fork", LBA = 00000001179, Forced
"Left fork", LBA = 00000001178, Forced
"Left fork", LBA = 00000001176, Forced
"Left fork", LBA = 00000001174, Forced
"Left fork", LBA = 00000001173, Forced
"Left fork", LBA = 00000001172, Forced
"Right fork", LBA = 00000001172, pattern 0x00
Maximal defect chain length is reached!
Try to analyse HDD manually or grow up maximal defect chain length!
LBA : 1172
Executing user command............................ : Show User Track Slip List
Posted: 16.03.12, 15:42
by Igor
If the case is still active, reach me please over some instant messenger.
Posted: 20.03.12, 21:08
by erick
I have the sam problem any idea?
Posted: 21.03.12, 06:47
by Igor
erick wrote:I have the sam problem any idea?
Reach me please over some messenger.
Posted: 03.05.12, 17:29
by erick
Hello Igor i use this topic viewtopic.php?f=34&t=7164
segate 7200.4 half capacity. well , red sector very slow but works. thanks for all yore help.
Posted: 03.05.12, 17:35
by erick
