7200.11 ST3500620AS HP24 size () problem
Posted: 19.01.12, 11:09
by BSIT
Hi.
Patient hdd is 7200.11 ST3500620AS HP24 with size () problem.
it can't access sa because HP OEM,
so i change firmware to SD1A with firmware utility download from seagate homepage.
then PC3K can access SA.
i tried solution for 0 GB.
but can't work.
MS010C.SDD1.AQ1700.
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C008E, List Offset 00000000, File Error 00000001
Collecting Sys Files Infos...
F3 T> Len
0 2
1 2
2 16
3 1880
4 9
5 4
6 66
7 1
8 2400
9 1
A 2251
B 1000
C 64000
D 160
E 432
F 223
13 8
15 100
16 2
17 40
19 24
1A 33
1B 1
1C 9
1D 128
1E 128
1F 640
22 80
23 80
24 80
25 80
26 80
27 80
28 80
29 80
2A 9
2B 579
2C 432
2D 432
2E 432
2F 432
30 432
31 432
32 432
33 4576
34 640
35 26
Collecting CP Infos...
ID MemOffs Len
0 6020100 33792
1 6020000 256
4 4001000 4096
602BE00 4096
total 8192
5 6C000 81920
8 10070000 948
A 609F5B0 1024
12 100D4000 104
13 60AA400 544
14 60AA620 64
15 0 524288
1B 60A9728 3288
1C 60A95E8 320
1D 60201A0 208
1E 6020390 2320
ID MemOffs Len
0 6020100 33792
1 6020000 256
2 6020270 288
4 4001000 4096
602BE00 4096
total 8192
5 6C000 81920
6 1FDC40 40996
8 10070000 948
A 609F5B0 1024
12 100D4000 104
13 60AA400 544
14 60AA620 64
15 0 524288
16 6020100 32
17 6021690 1744
1B 60A9728 3288
1C 60A95E8 320
1D 60201A0 208
1E 6020390 2320
1F 6144680 1224
20 6144B48 72
Collecting CP Infos completed
Detecting Phys Sct Size...
WARNING! It`s probably HDD have "Translatioin violation (0 GB)" problem
Try the command: Solution for problem "Translation violation (0 GB)"
From menu: Tests -> Solutions
Test : Solution for problem "Translation violation (0 GB)"
HDD capacity restrict. check (SetMax)...
HDD capacity restrict. check (SetMax)............. : Error
SMART erase....................................... : Ok
COM port reconnection...
Translator regeneration........................... : Ok
Solution for problem "Translation violation (0 GB)"......... : Error
so i tried command m0,6,2,,,,,22.
Rst 0x10M
RAP subfile error 200f
F3 T>m0,6,2,,,,,22
F3 T>
i's not work either.
how can i recover it?
