ST2000DL003-FIRMWARE-CC32-BUSY
Posted: 29.11.11, 08:34
by OHMYDATA
The Seagate driv can not detectd.
On label
Model : ST2000DL003
FIRMWARE : CC32
P/N: 9VT166-301
Entering the Utility I select the Barracuda 7200.12, and start the utility. I receive the error HDD ID has not been read.
select Yes and the utility opens.
The BSY on and it can not read the hard drive model and Serial..
Running the Utility the hard drive is not recognized but the drive spins up,
there is no clicking sound,
and the log screen shows
Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
User Data Base 00991490
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011982C 4011793C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00001144
[RSRS] 0BCB
ProcessRWError -Read- at LBA 00067304 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067304!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
ErrorSegmentOffset = 0000
ProcessRWError -Read- at LBA 0006738B Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006738B!
Status = 0000
ProcessRWError -Read- at LBA 00067386 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067386!
Status = 0000
ProcessRWError -Read- at LBA 00067381 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067381!
Status = 0000
ProcessRWError -Read- at LBA 0006737C Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006737C!
Status = 0000
ProcessRWError -Read- at LBA 00067377 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067377!
Status = 0000
ProcessRWError -Read- at LBA 00067372 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067372!
Status = 0000
ProcessRWError -Read- at LBA 0006736D Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006736D!
Status = 0000
ProcessRWError -Read- at LBA 00067368 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067368!
Status = 0000
ProcessRWError -Read- at LBA 00067363 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067363!
Status = 0000
ProcessRWError -Read- at LBA 0006735E Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006735E!
Status = 0000
ProcessRWError -Read- at LBA 00067359 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067359!
Status = 0000
ProcessRWError -Read- at LBA 00067354 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067354!
Status = 0000
ProcessRWError -Read- at LBA 0006734F Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006734F!
Status = 0000
ProcessRWError -Read- at LBA 0006734A Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006734A!
Status = 0000
ProcessRWError -Read- at LBA 00067345 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067345!
Status = 0000
ProcessRWError -Read- at LBA 00067340 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067340!
Status = 0000
ProcessRWError -Read- at LBA 0006733B Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006733B!
Status = 0000
ProcessRWError -Read- at LBA 00067336 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067336!
Status = 0000
ProcessRWError -Read- at LBA 00067331 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067331!
Status = 0000
ProcessRWError -Read- at LBA 0006732C Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006732C!
Status = 0000
ProcessRWError -Read- at LBA 00067327 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067327!
Status = 0000
ProcessRWError -Read- at LBA 00067322 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067322!
Status = 0000
ProcessRWError -Read- at LBA 0006731D Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006731D!
Status = 0000
ProcessRWError -Read- at LBA 00067318 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067318!
Status = 0000
ProcessRWError -Read- at LBA 00067313 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067313!
Status = 0000
ProcessRWError -Read- at LBA 0006730E Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0006730E!
Status = 0000
ProcessRWError -Read- at LBA 00067309 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067309!
Status = 0000
Reconstruction: EXCEPTION: Error in Header and ALL Footers.
Recon Last Chance
ProcessRWError -Read- at LBA 00067390 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00067390!
Header ID FFFFFFFF SeqNum FFFFFFFF
Reconstruction: EXCEPTION: Failed Final Recon Check: Burly Case
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
Please advice^^
Re: ST2000DL003-FIRMWARE-CC32-BUSY
Posted: 26.06.13, 11:15
by dataq
Did you find a solution to this drive? We have a similar ST31000DM003 CC48 with BSY problem and similar log output.
