Seagate ST3500320AS
Posted: 31.10.11, 14:19
i've got one HD wich starts with short scratch sound (sorry, I can't attach audio files, it's not allowed).
When running utility status the HHDD information is the following:
Model: ST3500320AS
Serial: 9QM367XM
Firmware: SD15
Capacity: 54,49 GB(114 270 345)
As you can see Capacity is wrong (should be 500GB (976773168) ).
When running HDD resources backup (ROM, CP, modules and ID pages) everything is saved and OK.
Testing heads result is:
Head 00 Resistance 00C1
Head 01 Resistance 00B7
Head 02 Resistance 00B4
Head 03 Resistance 0108
When viewing SMART, error HHD Readiness timeout (10000 ms) and HD enters in BSY mode.
I suspect that heads may be bad.
It's interesting to recover data, but not critical.
Any help to proceed?
Thanks.
Model: ST3500320AS
Serial: 9QM367XM
Firmware: SD15
Thanks.
