Seagate 7200.12 CC35 - size()
Posted: 23.07.11, 03:52
by DatalabNZ
Tech Key...
Requesting FW Pkg ver ........ PH0G7B.CCD3.BZ1E2H.
Collecting Sys Files Infos...
ID Len
0 4
1 2
2 16
3 3787
4 12
5 4
6 66
7 1
8 4800
9 1
A 2251
B 1000
C 64000
D 160
E 432
F 223
13 8
15 100
16 2
17 40
19 24
1A 33
1B 1
1C 9
1D 128
1E 128
1F 640
22 80
23 80
24 80
25 80
26 80
27 80
28 80
29 80
2A 9
2B 1172
2C 432
2D 432
2E 432
2F 432
30 432
31 432
32 432
33 4576
34 640
35 26
3A 4
Collecting CP Infos...
ID MemOffs Len
0 6037200 33792
1 6037000 512
4 4002C00 4096
602BE00 4096
total 8192
5 6C000 81920
8 40070000 948
A 60B48E0 2048
12 400D4000 196
13 60C0AC0 864
14 60C0E20 96
15 0 524288
1B 60BE8C4 8700
1C 60BE784 320
1D 6037220 352
1E 60374B0 2416
ID MemOffs Len
0 6037200 33792
1 6037000 512
2 6037380 304
4 4002C00 4096
602BE00 4096
total 8192
5 6C000 81920
6 277E44 40996
8 40070000 948
A 60B48E0 2048
12 400D4000 196
13 60C0AC0 864
14 60C0E20 96
15 0 524288
16 6037200 32
17 6039240 1216
1B 60BE8C4 8700
1C 60BE784 320
1D 6037220 352
1E 60374B0 2416
1F 6184670 1224
20 6184B38 72
WARNING! It`s probably HDD have "Translatioin violation (0 GB)" problem
Try the command: Solution for problem "Translation violation (0 GB)"
From menu: Tests -> Solutions
Collecting CP Infos completed
Tried User Command - Clear SMART - Terminal : reply timeout error (tried manualy with N1 but same result)
T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 4 0
Head 0: entries 1 slips 0
Head 1: entries 0 slips 0
Head 2: entries 0 slips 0
Head 3: entries 0 slips 0
Total Entries 1 Total Slips 0
Tried Isolate motor
F3 T>/2
F3 2>Z
ExecuteSpinRequest
HighPowerMode = 0100
DiagError 00006002
F3 2>U
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.424 secs
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024EDB5
Any ideas welcome - Thanks :!:
Re: Seagate 7200.12 CC35 - size()
Posted: 28.07.11, 09:25
by Igor
Try to perform next steps:
run utility
turn power on
wait ready state
ctrl+z
spin down
spin up
regenerate translator (from user commands menu or manually)
clear smart.
Paste here log if you will not get success.
Posted: 02.08.11, 04:14
by DatalabNZ
Spin Down Complete
Elapsed Time 511.291 msecs
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.344 secs
F3 2>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = 2DF8
Init SMART Fail
Posted: 02.08.11, 09:48
Much of the 7200.12 series require short circuit to allow translator to rebuild...
Posted: 06.08.11, 20:46
by einstein9
DatalabNZ wrote:Spin Down Complete
F3 2>U
ExecuteSpinRequest
ExecuteSpinRequest
Spin Up Complete
F3 2>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
Init SMART Fail
clear Smart then Trans. Reg.
and post the log here again for this process
Posted: 15.08.11, 04:42
by DatalabNZ
With read channel shorted
F3 1>N1
Failed to load overlay 00000004
LED:000000CC FAddr:0028540B
F3 T>m0,6,2,,,,,22
Init SMART Fail
Posted: 15.08.11, 09:37
by mvg
I too have the exactly same problem on a CC44 firmware ST3250318AS (7200.12)
SMART clearing command gives LED error in terminal. I am trying to copy the SMART module from similar drive and trying to clear afterwards.
Will update later. Any more ideas?
Mathew
Posted: 29.08.11, 09:04
by mvg
No luck on this drive yet
Mahew
Posted: 29.08.11, 16:54
by Igor
mvg wrote:No luck on this drive yet
Mahew
If you see LEDCC error after trying to clear smart, it may mean that heads are bad.
Posted: 07.09.11, 13:49
Is this solved yet?
If not send me PM with skype name (if you have), maybe I can help.
