ST3500320AS UNKNOWN PROBLEM.
Posted: 15.07.11, 08:46
by OHMYDATA
1. HDD INFORMATION
Model : st3500320as
Family : 7200.11
FW : SD15
After power on, sound ok, no clocking, but wait on bsy about 1~2 minute and go to ready status.
Model not detected.
After hdd id read, terminal log display
LED:00000047 FAddr:00231110
What's meaning of
Please advice^^
Re: ST3500320AS UNKNOWN PROBLEM.
Posted: 20.07.11, 16:49
by ACE_Admin
Tell me is the drive is spinning after one minute ?
If not, you may try to recalibrate it.
1. press ctrl-z within "Terminal" tab
2. make sure F3 T> is displayed
3. type T>/2 and press enter
4. type 2>U and press enter
That should recalibrate your drive. If there is a problem error will appear within the terminal.
If commands will work, try to view the smart with
F3 T>/1
1>N6
1>N8
Then tell me the results.
If smart will report you a big output with errors, you may clear it with
1>N1
Then restart the drive and see if anytning is changed.
The error description did not give us much "Prefetch abort exeption".
If the methods above will not help try to find a donor with same model , resolder ROM and put its logic board on patient.
