ST3250318AS
Posted: 13.05.11, 17:47
I have a problem with one of those drives.
It does not spin up and in terminal it continuously reports "Rst 0x08M" it seems it's on a loop of hard resets..
If I connect only the PCB the same thing happens. I tested the resistances on the motor coils they are around 8.5 ohm,
I also tried the R/W channel short but still nothing happened.
What should I do next? Should i look for donor pcb?
