ST2000DL003 FIRMWARE PROBLEM
Posted: 03.05.11, 09:02
by OHMYDATA
i have a ST2000DL003 with FW CC31 firmware failed like a Baracuda 11.
Not detect in bios but normal sound.
I tried to fix with hyper terminal but fail.
Please help.
Re: ST2000DL003 FIRMWARE PROBLEM
Posted: 03.05.11, 09:30
by dmarques
Never seen that drive.
Is that the model? And what's the family?
Can you post a picture of the label?
Posted: 03.05.11, 10:22
by OHMYDATA
Please refer attached picture.
- st2000dl003.jpg (60.41 KiB) Viewed 9898 times
Posted: 04.05.11, 18:07
by dmarques
Now I see it. LP series.
Can you shows terminal log?
Posted: 04.05.11, 22:42
by einstein9
what is the problem with this drive?
and when it powers up, does the sound looks OK or clicks?
again some terminal log of the Init. from termianl
Posted: 12.05.11, 03:32
by OHMYDATA
Capacity 0 MB problem.
After power on, sounds ok.
Posted: 13.05.11, 09:32
by OHMYDATA
Shows terminal log:
Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
User Data Base 009907F0
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 4011985C 4011796C
Seg Write Preamble VBM start: 000010A7 end: 000010CE
Footer - start: 000010D0 end: 000010F7
Seg Read Preamble VBM - start: 000010F9 end: 00001120
Footer - start: 00001122 end: 00001149
Nonvolatile MCMT sequence number 00006299
[RSRS] 1D74
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch
00003219 00000000
[MCMTWS]
Reconstruction Fail: Burly Case
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00001001
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00001001
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1E1
ASCII Diag mode
Posted: 13.05.11, 09:33
by OHMYDATA
Shows terminal log:
Rst 0x40M
(P) SATA Reset
MCMainPOR: Start:
[RSRS] 1D74
00003219 00000000
[MCMTWS]
ASCII Diag mode
Posted: 13.05.11, 13:15
by dmarques
What fixes did you apply already and what was the results?
Posted: 14.05.11, 03:26
by OHMYDATA
Clear smart
T>/1
1>N1
Clear defect list & translator regenerate.
T>i4,1,22
T>m0,6,2,,,,,22
But keeps bsy.
Posted: 20.05.11, 20:16
by einstein9
when you power it ON, just listen carefully and listen
does it spin normal? on the begin. ???
Posted: 28.05.11, 05:02
by OHMYDATA
Yes, it spins normal.
Posted: 28.05.11, 10:12
by einstein9
both clearing smart & translator reg. were ok or with problems?
Posted: 31.05.11, 02:46
by OHMYDATA
It works with no error.
