ST3250310AS not responding
Posted: 05.04.11, 10:02
by aribot
I have a Seagate ST3250310AS 7200.10 NHawk Plus which is not responding. There should be some problem with power, but I can't detect it.
I've checked PCB contacts and OK.
I've checked TVS and seems OK.
No SATA green led on when powered on.
When powered on, endless message in terminal:
2000 F650 F76A F768 0000 0000 0000 009F 0001 005F 0003 0001 0038 0008 F768
0001 0000 014A 00FF FA46 D000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
DD1C 1D43
Powering HDD ins Safe Mode hangs PC3K.
Same behaviour when I insolate commutator chip.
I have a donor with identical properties, what else can I check?
Thanks.
Re: ST3250310AS not responding
Posted: 08.04.11, 12:17
by ACE_Admin
Hello Aribot
Could you please provide terminal output from the beginning? It's not clear what happens with the drive.
Probably this hard drive has logic board problems.
