ST9250315AS
Posted: 31.03.11, 14:36
by mojimorady
Dear guru
accept my regards
i have a hdd in the following specification :
seagate 2.5 " , 250 GB , sata
after i connect it to pc3000 in seagate F3 window it reflects 0GB capacity ,
i tried to to repaire it using the soloution
but after spin up , when it wants to clear the s.m.a.r.t , pc3000 shows me :
drive is not ready
after i tried to clear s.m.a.r.t in seagate F3 window manually , it said ( drive is not ready ) again and the terminal error
are as follows :
LED:000000CC FAddr:00237CAB
now what should i do ?
thanks for your soonest reply
mojimorady
Re: ST9250315AS
Posted: 05.04.11, 08:58
by ACE_Admin
Please, turn on "show additional diag messages in terminal" option and try to clear smart once more.
Then terminal should display you more messages, copy them here.
Re: ST9250315AS
Posted: 05.04.11, 11:55
by mojimorady
dear Roustam
thanks for your responce
i did what you said , and i used soloution for HDD LOCK , the terminal is as follow :
Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180
ESLIP mode
Init SMART Fail
lots of apperciation for your soonest reply
best wishes
mojimorady
Re: ST9250315AS
Posted: 24.08.11, 12:57
by Bruno
Dear Roustam
I can't find the Parameter"show additional diag messages in terminal".
Please tell me how i can find them.
I have a ST9250410AS with FW:0006HPM1
On the first start in pc3k the HDD Lock LED CC Error occurs.
After i tried to solve with the Solution of pc3k, i can see no more, but the solution can't solve the problem. The HDD make the same noises like befor i tried the LED CC solution.
See Log:
Tech Key...
Drive not ready
Spin Up Complete
Elapsed Time 2.071 secs
F3 2> : Solution for problem "HDD Lock (LED: 000000CC)"
Spin Up...
Drive not ready
Re: ST9250315AS
Posted: 07.09.11, 14:11
Bruno wrote:The HDD make the same noises like befor i tried the LED CC solution.
Maybe the problem is elsewhere. Standard LED errors do not affect HSA or spindle so should be no abnormal noises.
