Seagate ST9500420AS
Posted: 17.01.11, 11:45
The problem i'm having with this drive is that it stops reading after lba 233584. I have found reassigned sectors list empty, so I'm guessing someone else tried to recover the data before me. The drive was outsourced to me, so the client can't tell much info about what happened before.
After I activated the "show additional diag msg in terminal", I got this output.
Anyone else encountered this before?
Thanks in advance.
Code: Select all
Rst 0x20M
(P) SATA Reset
RAW OFF
PASS
RW: Error processing Performance Parameter File: 203C
Thanks in advance.
