ST380011A- Self Scan Problem
Posted: 02.09.10, 14:56
by datacare
I have tried self scan for remove the bad sectors. After finishing the Self Scan the drive is not detecting, i have restore the CERT Code and HDD ID template also, but there is no use.
Drive details as below
ST380011A
Firmware:-8.01
With regards
Datacare
Re: ST380011A- Self Scan Problem
Posted: 09.09.10, 11:22
by ACE_Admin
Can I have the logs from terminal, this drive show you?
Posted: 10.09.10, 07:36
by datacare
I got the following Termial log
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .248
Cert Table loaded
No script first instruction.
No valid SeaDex script on disc.
Begin Test 08
Not Power Cycling
SkpCylList deleted
Sys= 0E940-0E9BF 0280 SPTK on sys trks
<empty>
drive must be reformatted
Skipping MDW oversample s/n cylinders.
