ST3100528AS CC37
Posted: 08.07.10, 12:32
by zeroalpha
This drive comes ready and I can do a db backup, but no access to surface
Rst 0x20M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002WriteDCOInfo FAILED during Initialization
RW: Error processing Performance Parameter File: 203C PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
Re: ST3100528AS CC37
Posted: 12.07.10, 14:05
by zeroalpha
I figured out the solution.
Posted: 15.07.10, 07:13
by datacare
I am also facing same problem. can you tell me how to solve this one.
Sundar
Data Care Services
Posted: 18.07.10, 00:17
by Issam
heads should be replaced
Posted: 19.07.10, 12:40
Issam wrote:heads should be replaced
This is not the case, heads are not damaged.
I remember similar case I had and repaired with old translation repair command, 'm0,2...'. In my case I had full ID also.
