Problem with Seagate ST91208220AS Momentus PSD 120Gb
Powermax
Postby Powermax » 23.04.10, 12:49
Hi to all.
I have a strange problem with that Seagate HDD. When i connect it to Pc3K, and power on, it start normally and no knock i can ear ( I can ear normal heads sound for start positioning, too). The problem is that the Hdd stay in Busy state.
I see the terminal report at power on, is like the follow :
Reset
4096k x 16 DRAM
LARAMIE - 1_Disk S-1F 07-09-07_13:15
HM SFI
(P)
.FSTOP(0, 2400).FA_State(0).FA_CNT(3)
LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(88).VBM(3C88).SAVH(88,88).HVBM(3C60),LVBM(3C60).ERROUT
TblRdErr
NVC:Reconstructing
LBA(FFFFFE87).LEC(0).X(18).PG(1EEF6),SABNR(118).VBM(3C88).SAVH(118,118).HVBM(3BD0),LVBM(3BD0).ERROUT
TblRdErr
Some one can help me to solve this issue ?
Thank you very mutch to all !! :D
Re: Problem with Seagate ST91208220AS Momentus PSD 120Gb
Postby AJ2008 » 23.04.10, 13:51
The Laramie is a Hybrid drive, and is quite peculiar. Specfic fault cannot be confirmed, but it seems that information within the ROM chip is invalid. A donor with same ROM version is required, then a simple change of PCB should allow for initilisation, or at least a more informative Terminal output.
Continuum
Postby Continuum » 03.09.10, 07:26
Did you manage to fix this? I have a drive with the same problem.
Powermax
Postby Powermax » 03.09.10, 10:07
The problem was on PCB. I found a new PCB with the same ROM version, and i can recover all.
Bye
