I got the drive which is encrypted (that is what the owner says). I connect to PC3000 and it will come up ready but the max LBA is not showing. It will show only a part of the max LBA and the size is 128MB. What can be the problem here and how to solve it?
Model: ST980816AS / Firmware: 3.ADB
Any suggestions?
Seagate Momentus 5400 FDE.2
Re: Seagate Momentus 5400 FDE.2
DR_Ireland wrote:I got the drive which is encrypted (that is what the owner says). I connect to PC3000 and it will come up ready but the max LBA is not showing. It will show only a part of the max LBA and the size is 128MB. What can be the problem here and how to solve it?
Any suggestions?
I think with this HDD the encryption is at a SA level.
AJ2008 wrote:DR_Ireland wrote:I got the drive which is encrypted (that is what the owner says). I connect to PC3000 and it will come up ready but the max LBA is not showing. It will show only a part of the max LBA and the size is 128MB. What can be the problem here and how to solve it?
Any suggestions?
Well ,
Seagate Is Bend Upon Making Our Life Hell
Amarbir @ HDDGURU
I believe that terminal is disabled in these drives, so the Seagate utility will not work
Safe Mode works, but is restricted a little.
- avenger-fr
Excuse me, but for me I haven't Safe mode (F3 series) and when we would access in terminal I have
>(1Ah)-Serial Port Disabled
I have make a video of my little tool for break the problem with FDE who are "Trusted" (not ATA password but fully encrypted). You can see at http://www.hddsync.com/services/unlock-fde/
Maybe you need this (if you have the USER password)...
- avenger-fr
Ps : We can't access to SA on this disk , I have just read ID page , nothing else ...
You can see the log :
Collecting Sys Files Infos...
Error collecting Sys File Infos!
Error : Error requesting command state "En Tech" (<bit3>)
Collecting CP Infos...
Error collecting CP Infos!
Collecting CP Infos completed
Soft reset ...
Soft reset ...
Test : Reading ROM
Reading ROM to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST9250424ASG-DEC6-5TH0M05A\Data\ROM\
Error : CP ID 15 is not found!
Result............................................ : Error
Test : Modules reading
Test : CP reading
CPs are not selected
Requesting FW Pkg ver ........
CA0AC2.DEM2.CA201S.DEC6
Modules are not selected
Recalibration attempt ...
Ok
Soft reset ...
Hard reset ...
Soft reset ...
Terminal : error detecting HDD terminal baud rate
Error switching COM port baud rate
Soft reset ...
Soft reset ...
Test : Reading ROM
Test : CP reading
Ok
Soft reset ...
Hard reset ...
Soft reset ...
I came with the same hard disk, but I repaired it and then from Seagate Casing itself I have recovered the data.
Vikas
Vikas
Vikas Seth
Data Track System
http://www.datatracksystem.net
http://www.facebook.com/datatracksystem.net
Data Track System
