Seagate head compatibility
Posted: 12.06.09, 00:33
Does anyone know for sure what is the correct criteria when selecting a donor for head replacement in Seagate 7.200.X ???
For example (7200.7):
Pcb is ok, tested with one of the donors
Hdd to recover data:
MODEL: ST380011A
S/N: 5JVMTVNZ
P/N: 9W2003-371
HDA P/N: 100316339
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05412
SITE CODE: WU
in red the few differences
between donors and bad hdd
Selected donor1:
MODEL: ST380011A
S/N: 4JV070HP
P/N: 9W2003-371
HDA P/N: 100316764
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05154
SITE CODE: TK
Selected donor2:
MODEL: ST380011A
S/N: 5JVWW18B
P/N: 9W2003-399
HDA P/N: 100348969
CONFIG: CXN-01
FW: 8.01
DATE CODE: 06333
SITE CODE: WU
Selected donor3:
MODEL: ST380011A
S/N: 5JVM28V3
P/N: 9W2003-314
HDA P/N: 100316764
CONFIG: D5C-03
FW: 8.01
DATE CODE: 05396
SITE CODE: WU
But after exchange only head mask in terminal
After testings, heads were returned to original donors
All of them returned to work perfectly, all 3 cases!
full lba scan test
I noticed that in top of a internal plastic piece that hold
terminals to the pcb from the inside, there was 2 writings:
1st = AP2-C
2nd = AG-C
Selected donor1:
1st = AP2-CK
2nd = TI-C
Selected donor2:
1st = AP2-C
2nd = TI-CR
Could it be that the 2nd marking must be AG-C ??
I opened about 8 hdds, the only one with AG-C was the bad one
All the others had TI-XX for 2nd marking and AP2-CX for the 1st
(where X stands for something or even not present)
Any advice is welcome
Thank you
-BR-
MODEL: ST380011A
S/N: 5JVMTVNZ
P/N: 9W2003-371
HDA P/N: 100316339
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05412
SITE CODE: WU
Selected donor1:
MODEL: ST380011A
S/N: 4JV070HP
P/N: 9W2003-371
HDA P/N: 100316764
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05154
SITE CODE: TK
Selected donor2:
MODEL: ST380011A
S/N: 5JVWW18B
P/N: 9W2003-399
HDA P/N: 100348969
CONFIG: CXN-01
FW: 8.01
DATE CODE: 06333
SITE CODE: WU
Selected donor3:
MODEL: ST380011A
S/N: 5JVM28V3
P/N: 9W2003-314
HDA P/N: 100316764
CONFIG: D5C-03
FW: 8.01
DATE CODE: 05396
SITE CODE: WU
full lba scan test
1st = AP2-C
2nd = AG-C
Selected donor1:
1st = AP2-CK
2nd = TI-C
Selected donor2:
1st = AP2-C
2nd = TI-CR
Thank you
-BR-
