I tried 'solution for problem "hdd lock"' but error message
Posted: 25.03.09, 09:09
by Sung-Kwon Jung
I have seagate hdd 7200.11
please tell me how to do
- seagate2.jpg (246.46 KiB) Viewed 4261 times
Re: I tried 'solution for problem "hdd lock"' but error message
Posted: 25.03.09, 10:15
Your 7200.11 has new unsupported firmware which does not allow terminal access. PC3000 alone is not yet able to repair this hdd.
Posted: 27.03.09, 11:06
by steven
I think sooner ace will release the new update... just wait for it
Posted: 27.03.09, 15:19
The new update will not help. The HDD itself seems to block out any terminal access at all. Shorting the PCB locations as instructed in the new F3 manual did not help me when I had this problem, but there is a solution via using a donor with supoprted fw.
Posted: 28.03.09, 05:07
by steven
using donor with supported F/w. seem it is a Good idea.
can you be more detail... thanks
